85-92 compatibility?
Old Oct 21, 2012 | 11:38 PM
snarley's Avatar
Car: 1987 z28 camaro
Engine: 305cid lb9
Axle/Gears: Base Z28 drum 3:23 ]
just wondering if the fenders from an 85-87 camaro will fit on a 92 z28. i know the bumpers are different but i have the abillity to pick up a parts car for 200 bucks. answers greatly appriciated.
Old Oct 22, 2012 | 12:18 AM
GVMV's Avatar
Car: 1985 Buick Regal T-type
Engine: TBI 5.7
Transmission: 2004r
Re: 85-92 compatibility?
85-90 are the same
91-92 are specific.
Old Oct 26, 2012 | 01:14 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
If they're like Firebirds, the fenders will bolt up, but they just won't have the mounting locations for the 91-92 ground effects.
Old Feb 8, 2013 | 07:19 PM
blue92z28's Avatar
Car: 1992 Camaro Z28/1991 CamaroRS/88GTA
Engine: 305...with a 350 waiting to go in.
the camaro bumpers are the same from 85-92
the 82-84 had a specific bumper
the rear bumper is different from 85-90 the 91-92 is a newer style but bolt up to any year 1/4s provided you buy the correct 1/4 panel ground effect
now the fenders are specific 85-90 and 91-92 the difference being with the front spoiler and how it attaches. 85-90 it has two bolts and two holes. the 91-92 front spoiler has a "flap" with a hole in it where a retainer type clip fits in holding the spoiler to the fender. now you can modify a 85-90 with a grinder or anyway to make a slit --------------------- approx that long about a 1/8" wide x 2
hope this helps
Old Jul 8, 2013 | 04:41 PM
DrNBody's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: LB9 305 TPI
hope this helps
Just what I needed to know!
Old Jul 13, 2013 | 11:23 AM
bladehand's Avatar
Car: Iroc z 1990
Engine: 5.7 tpi flat top pistons
Transmission: 5 speed
if 85-90 fenders are interchangable, the facia ( noses ) are all the same ? p/n 16503496 in my 1990 dealer parts book, and if that's so then all hoods would be compatable ? or would I likely encounter different hinge and support mountings?
Old Jul 13, 2013 | 11:46 AM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Hoods will all fit the same- however, I'm not sure if the way the blisters mount is different than the louvers mount on the 85-90.
From tearing down several different years of parts cars, the hinges are the same.
Old Jul 13, 2013 | 11:58 AM
bladehand's Avatar
Car: Iroc z 1990
thank you, my iroc hood is a little crumpled on the leading edge, If I could find a plain RS or standard hood I might just swap for it, no matter how well I washed and rinsed the car it always had dust trapped under those louvers, annoying. I may just repair the existing hood fill in the louver mounting holes and paint the naca molding detail black, also I think I saw some of the years used decals ? thanks for your quick reply I am on my way to the junk yard to pick up a fender, dern teenage daughter..
Old Jul 13, 2013 | 01:24 PM
I've got both hoods- but I'm clear across the country!
Old Jul 14, 2013 | 06:37 PM
bladehand's Avatar
Car: Iroc z 1990
thanks for the reply, I am going to see if I can straighten this one out, if I do then I'll have to find the drivers side louver, dealer here said no longer available from GM
Vintageracer
Sep 24, 2017 12:34 PM
jerflash
Sep 23, 2015 09:21 AM
Ward
Feb 14, 2005 03:45 PM
Calderone
Jul 9, 2002 10:55 AM
