Hood pin help? Or latch fix?
Old Jan 4, 2013 | 12:25 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Ok im tired of dealing with my hood, i can never open it unless i drive around with the lever pulled until it pops(dont really pop but comes open)
Should i just get hood pins installed or is the latch wire cheap enough to just go buy? where would i go about buying one?
Thanks!
Old Jan 4, 2013 | 12:35 PM
toomany's Avatar
Re: Hood pin help? Or latch fix?
Is the cable broken? What about the sheath? If the outer sheath is cracked/broken then when you pull the lever it will flex at the break...not pulling the latch all the way. Have you cleaned and re-lubed the latch? A real good cleaning will go a long ways as to how they work. The latches get gummed up over the years. Last thing would be to have the proper adjustment. But that shouldn't have changed unless you were in an accident or moved some body parts around.
Old Jan 4, 2013 | 01:17 PM
Jk_Under's Avatar
Engine: 305 5.0L
yea its messed up, i had to cut into it in order to get my hood opened, just cut it and pulled the latch wire in the middle.
Old Jan 4, 2013 | 11:18 PM
toomany's Avatar
You should be able to find a replacement cable easy enough then. Either from junkyard or from the classifieds here. Shouldn't cost more than a few dollars. You may even be able to use one off of another vehicle. Heck...I'll look around in my stash of parts for one. Don't remember saving one, but you never know. If I've got one I'll send it out to you.
Old Jan 5, 2013 | 04:38 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
ebay has them starting at 20 foor the cable
Old Jan 9, 2013 | 01:40 PM
Jk_Under's Avatar
Engine: 305 5.0L
Thanks man, you've been helpful, im kinda in a debate though. I like hood pins, but i like being able to pop my hood from the inside, idk, the latch pull is connected to the cable itself.
Old Jan 10, 2013 | 08:34 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
IMO hood pins are kinda tacky, but it's you car. I like the 1/4 turn lock pins or whatever they are called. They sit flush with the hood and you use a screwdriver or a coin to turn them.
Old Jan 10, 2013 | 02:54 PM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
If you can aford them I'd go for a set of those aerocatch hood pins. Those are so slick!
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
bryan623
Aug 10, 2015 11:33 AM
