Strange rattle, anyone know what this is?
Old Dec 9, 2000 | 09:05 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
There is a strange rattle coming from the far passenger side of my camaro. I hear it at errattic intervals, and cant figure out where its coming from. It is not a high pitched squeak, more low pitched, sounds like something is loose or somethin'.
I cant figure it out, because I cant look at it while I am driving. I also cant tell whether or not its coming from something outside or inside.
Anyone got any ideas?
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 9, 2000 | 09:43 PM
camaro 22's Avatar
your exhaust purhaps? a plastic panel in the back? the plastic vent inside the door fame? speaker frame loose?
Old Dec 9, 2000 | 09:50 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Welp, I know it isnt a panel in the back, too far forward to be a vent in the door.
the noise sounds like it is coming from the front 1/4 of the car...
thanks,
anything else I should check?
Old Dec 10, 2000 | 12:05 AM
turbo497's Avatar
try spraying passenger side seat mech with wd40 this is where i had nosie
3.8 turbo 20th anniversary transam #497 first owed by Clifford Williams, Bass player from rock band AC/DC
Old Dec 10, 2000 | 02:44 AM
killrog22's Avatar
i had the same problem. Chech the ehaust clamp in front of the cat and that little clamp on the air hose that goes into the cat.
Old May 14, 2001 | 07:35 PM
tropez's Avatar
I just fixed a rattle in my front end: the X cross brace rods in front of the radiator touch right at the crossing of the X. A split rubber tube keeps the two rods from touching. The tube was turned around and the rods vibrated together at a certain rpm.
Old May 14, 2001 | 08:48 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If it seems to happen mostly when you are driving over a rough spot in the road, it could be the outboard brake pad is loose in the caliper. It's not dangerous, just annoying. Try lightly applying the brakes when going over a rough section, if the rattle stops, that's the culprit. You'll need to remove the caliper from the spindle and apply some 'Disc Brake Quiet' to the back of the pad and put it all back together. And make sure the 'tangs' on the pad are squeezed up tight to the caliper as well.
Hope this helps...
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
206+k mile LG4/5-speed
14.935@94.14
Old May 14, 2001 | 09:30 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I have a rattle in my passanger side A-Piller. When it starts up, I just reach over and hit the stupid thing, and that keeps it down for a few weeks!
Old May 16, 2001 | 04:02 PM
bird67's Avatar
I found the only sure-fire way to get my 'bird to stop rattling and squeaking is to park it. It's now at the beauty parlor getting stripped and repainted. I'm sure it hasn't squeaked once since I left it. When I get it back, I plan to keep the top down as much as possible and let the wind noise drown out the squeaks.
Old May 17, 2001 | 05:37 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks for the replies guys!!
I think I got it covered though... It is one of the rubber stoppers that supports the hood at that corner.... the stopped dried up and cracked up and broke off!!! So I think that the bolt thing is scratching my hood up from the inside...... Im gonna get another rubber thing!
92 Rs 3.1/T-5
Its slowly but surely coming along.... I FIANLLY got a K&N... a little better!
AIM : Theonekiztope
ICQ: 8787542
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
jrdturbo
Mar 31, 2016 02:58 PM
BWilcox
Sep 20, 2015 12:19 PM
Ian Irvine
Sep 4, 2015 08:08 AM
