Speedometer Manipulation
Old May 24, 2001 | 10:02 PM
BadBowTie's Avatar
Is there a way to manipulate an 85-MPH speedo so it will read correctly with a 145-MPH face? I just want to put a 145 (or even a 120) overlay on my 85-MPH speedo so I don't have to go through the hassle of getting certification of the odometer mileage.
'86 Camaro SC 2.8 V6, 5spd, T-Tops
Mods:
(Performance)
Flowmaster cat back exhaust
(Non-Performance)
Pioneer DEH-P4000 head unit
Pioneer 6X9 Tri-Ax speakers
Jensen 8" dual voice coil sub
Blacked out tail lights and side markers (VHT
Nightshades spray tint)
Old May 24, 2001 | 10:20 PM
87 Firebird's Avatar
I'm sure that if you put a correct resistor in series with the needle acutator, it would work. It's just a matter of doing the right calculations. It would take a lot of tinkering, to boot. Perhaps if you hook a voltmeter in parallel with the connectors at the back of your cluster that are responsible for speed. Then, you can reproduce highway speeds using a power source in your work area. It'd be a ton of work, though...and you can't hook the resistor up right into the main signal, or the odometer wouldn't work...best of luck
Old May 25, 2001 | 12:01 AM
BadBowTie's Avatar
My Speedometer is mechanical (cable driven) not electronic.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
