Shifter Knob?
Old Jun 14, 2001 | 05:48 PM
Broodin-Doobie's Avatar
Shifter ****?
I know this is probably a pretty simple question, but how do you get the shifter **** off. It should just unscrew right? cause mine isn't comming off..
Old Jun 14, 2001 | 05:50 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
mine had trouble...
i took an old t-shirt, and wraped it around the boot, and then put vice grips on over the shirt, and sucured the the shifter arm. then unscrewed...(the shirt is to you don't hurt your leather boot..
Dewey 3:16
90 RS 305 TBI LO3
36mm/24mm swaybars, Spohn Panhard, SFC, LCA's, and RLB. "Wonder"bar, Edelbrock STB, and K&N.
Old Jun 14, 2001 | 07:57 PM
Jza's Avatar
Jza
need more info than that. is it manual or automatic? what year? firebird or camaro?
Old Jun 15, 2001 | 02:59 AM
86ZRICHIE's Avatar
if it's manual, then yeah, it should. if it's auto (82-87?) with a round shifter, take off the buton and you'l see a c-clip, pull it off and off comes the ****, if it's post 87 or has the square shifter, it should have a clip on the front of the post, take that out then try to pull it.
Old Jun 15, 2001 | 02:06 PM
deacon17's Avatar
If it's a 5-speed, spray WD40 up under the ****, let it sit, then try it. If that doesn't work, put some heat on it with a hair dryer and try again.
Old Jun 16, 2001 | 10:27 AM
Thanks, the wd40 and hairdryer thing worked perfectly.
Old Jun 17, 2001 | 12:10 AM
FiReBReTHa's Avatar
hey guys, what would you do for a 91 bird, auto?
i wanna start messing around with the console, but fear destruction.
thanx guys
91 FireBird 305 V-8
Edelbrock Catback,
ghetto rigged cold air intake,
"My G/f Once Wanted To Break Up Because Of Competition With The Car."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Jun 17, 2001 | 12:17 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
86ZRICHIE; I HAVE THE 86 ROUND PLASTIC ONE AND I WANT TO REPLACE IT WITH THE LEATHER RAPPED. HOW DO I TAKE THE BUTTON OFF? WILL THE C CLAP BE REUSABLE? DO I NEED A SPECIAL TOOL? THANKS
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Old Jun 17, 2001 | 12:22 AM
Duffster@Work's Avatar
FireBreatha... If you look on the front lower part of the ****, you should see a flat thing... get something like a small flattip and push in on the top and rotate in behind it... it will pull right out.
When you're done, should look like a large staple. The **** should lift right off after this...
Hope this helps
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Night rider327
Feb 25, 2016 09:50 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
