Painting interior
Old Jun 26, 2001 | 12:33 PM
Trent257's Avatar
Painting interior
is it possibly to paint the interior vinal parts, what kind of paint would i use. does it work good?
Trent
89 Firebird
305 v8 TBI
automatic
t-tops
Old Jun 26, 2001 | 06:18 PM
86ZRICHIE's Avatar
to answer your questions:
1. Yes
2. Duplicolor makes a vynl/fabric spray, but I'd try to find SEM's interior paint.
3. Yes it works good if you prep it right.
I'd recommend to wash the piece in warm water, then go over it with rubbing alcohol, then plastic prep (again an SEM product) then an adhesion promoter let that dry and paint it with light coats. Works like a charm. You can get away with less, but why not put in a little extra work to keep it from peeling or scuffing easily so you don't have to worry about it.
Old Jun 26, 2001 | 09:38 PM
zee28's Avatar
Car: 86 iroc
you cant add much to that.Make sre you take the time to prep it good or it will be a waste and look horrible when it starts to come off.
~mike~86 IROC-Z
Old Jun 27, 2001 | 03:19 AM
EnTwisted_Iroc's Avatar
Clear coating it is a must to and the fabric i did not like still feels fun to me like the normal paint does.
89 Iroc-Z 5.7 350 all stock looking for engine
also
73 Olds Omega
350 rocket
EdelBrock RMP Manifold
EdelBrock 650 Carb
Dual Flowmaster 2.25" with 3" tips American racing rims.
Old Jun 27, 2001 | 04:14 AM
One Eyed Jack's Avatar
clean it with alcohol and a toothbrush
get high grade rubbing alcohol so you dont get as much residue left over on the vinyl
Old Jun 27, 2001 | 04:40 PM
86ZRICHIE's Avatar
<font face="Verdana, Arial" size="2">Originally posted by EnTwisted_Iroc:
</font>
Yeah, duplicolor has that problem, except with the glossy black, that's why I say use SEM's interior spray, it'll most likely work better.
[This message has been edited by 86ZRICHIE (edited June 27, 2001).]
Old Jun 27, 2001 | 10:07 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Does anyone have any tips for the clear coat? Is it the same as painting the bumper covers? I have black and tan interior panels in my car, so I realy need this painting thing.
Old Jun 28, 2001 | 02:10 AM
86ZRICHIE's Avatar
are you going with black or tan? if you want a deep gloss black, then just go with the duplicolor or SEM gloss black, otherwise I think you might want to sand with 1500 or 2000 then shoot a few coats of clear on it. I'm not sure if the SEM products will need it, but the duplicolor colors other than gloss black I've heard problems and they needed clear over it.
Vintageracer
Jan 10, 2020 05:33 PM
Hawk312
Aug 22, 2017 08:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
