How much difference does Dynamat make?
Old Jun 29, 2001 | 10:44 PM
NCZ28's Avatar
I was thinking about putting some Dynamat around in the interior of my car. I was just wondering if this stuff was really good at keeping road noise out and music in. Also, is the spray any good, and what does it look like when applied?
Old Jun 30, 2001 | 12:41 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It helps, but is not a cure-all. Tightening all the fasteners and general de-squeaking are first priority. Also it is important to read the instructions on the dynamat installation. Good surface prep (clean) and warm temps are needed. I have also used Goop brand adhesive to mount some components. Do a knuckle-rap test to find the source of rattles, then goop them and use the dynamat. My doors do seem quieter and sound better closing now. Good luck, Lon.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Jun 30, 2001 | 02:45 AM
FiReBReTHa's Avatar
good amount, i doubt youd be disatisfied.
rear, above gas tank, rear hatch. allover.
behind seats. under seats.
for audio, continue on roof. SIDE panels. id use the spray inside of panels and hard to reach.
enjoy, email me with any "?"
later...
91 FireBird 305 V-8
Edelbrock Catback, Fourth Gen Console. i have six cupholders. all for starbucks!
ghetto rigged cold air intake,
"My G/f Once Wanted To Break Up Because Of Competition With The Car."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
God Created The Earth, And Then Turned Up The Bass
Old Jun 30, 2001 | 10:31 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
If you want something that works just as well as Dynomat, but is MUCH cheaper, look at B-Quiet.
http://www.b-quiet.com
Third Gen Project
1989 305 tbi Camaro RS Red/Red
Ram Air II Hood
Centerline Champ 500 Rims
Edelbrock Open Element
MacEwen White Faced Guages
"Stock?! Theres nothing "stock" about a stock car."
Old Jul 1, 2001 | 10:11 AM
camaro6spd's Avatar
I thought about this, what about the spray foam insulation for houses in cans, Great Stuff, that is the name, Great Stuff. Do you think I could spray that up in my T-Top frame nothing would protrud into it. Just in the roof frame. ????? I did not do it yeat because I don't know the side effects. Don't want to do something dumb to my car, unlike that ***** kid see, Import Sport look on a RS Camaro.
Old Jul 1, 2001 | 11:03 AM
orange rocket's Avatar
Watch out with how much you spray up there, because when it expands ALOT it could deform your exterior panels. I used it to fill in the spare tire well of my 93 Eldorado and worked great along with 250 sq feet of dynamat through out.
Frozer!!!
Jan 19, 2024 04:55 PM
Out-Cast
Mar 22, 2019 09:39 PM
onefreakz
May 14, 2018 12:15 PM
tmellott89
Aug 16, 2015 02:58 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
