How to access front D/S marker light?
Old Mar 28, 2013 | 06:47 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
My damn d/s marker light is out. Is there an easy way to get to this thing im missing? It looks like a real pain in the ***... i always hate when changing a bulb taks more then 10 mins
Old Mar 28, 2013 | 07:51 PM
82tarecaro's Avatar
Re: How to access front D/S marker light?
From underneath. There isn't really any secret to it. You should be able to look up and see it.
Old Mar 28, 2013 | 07:52 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
If you're talking about the front marker/turn light in the nose, Im not 100% sure on the firebirds, but the easiest way on camaros is from underneath. If you mean the side marker lights in the fenders, they are the same. Just reach up under the fender and its right there. They all take a 1/4-1/2 turn to release the socket from the light. No need to mess with the metal clips on the fender marker light, just turn the bulb socket and pull it out.
Old Mar 28, 2013 | 07:54 PM
82tarecaro's Avatar
Thinking about it now, I wonder if the front ground effects are in the way. I just took them out recently, but I had removed the ground effects for paint. I guess you could take out the clips from the inner fender liner and reach in that way also.
Old Mar 28, 2013 | 08:56 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Neither one of hose are in the way. I've removed and replaced mine with no problems with everything else still attached.
Old Mar 28, 2013 | 09:08 PM
insomniac's Avatar
Engine: 5.7 L98
yeah was talking about the side one.
Last edited by insomniac; Mar 28, 2013 at 09:08 PM. Reason: cant spell or type for ****
Old Aug 19, 2013 | 06:42 PM
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
There is plenty in the way on mine. Some brace and a vacuum storage tankball.
Old Aug 19, 2013 | 06:55 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Pull the headlight assembly or easier loosen the plastic fender liner.
Old Aug 19, 2013 | 07:40 PM
ramicio's Avatar
None of that is easy. This is so stupid. All for a freakin 194 corner light. It had a broken wire. Great. Can you get connectors with terminals anywhere? Nope! Everything is a freakin pig tail! Even though I have the tools to crimp terminals, all I can ever find are pig tails. I don't want splices in my wiring.
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
