Rear hatch alignment
Car: 85 trans am
Engine: 5.0 carbed
Transmission: TH700R4
Axle/Gears: 9 bolt
Sorry if this is a "stupid" question, but im not much of a body man myself. The rear hatch is moved toward the rear about a half inch, from the rear quarters, which obviously makes it hard to close, and looks bad as well. Looking at the 4 bolts on the interior side, i see three are "kind of" elongated to adjust, but one is not??! Do i have to elongated the holes myself, or does some one out there have experience with this, and maybe an easier, and/or better way?
Thanks in advance!!
Thanks in advance!!
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Rear hatch alignment
https://www.thirdgen.org/hatchalign
Try this, it usually corrects the problem and takes care of water leaks in the hatch area.
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
All of these cars had that large gap when they were new. There are many threads concerning this problem so use your own judgment. Personally I'd leave the gap alone so as not to cause other problems. The usual problem will be repaired using the above thread. The only thing I would do other than how that link describes is use urethane where the factory did to keep the hatch from sliding back on the glass again.
Engine: 4++,350 & 305 CIs
It takes a combination of hatch to glass and glass to hinge adjustment to get it correct.
And also a helper. There are many threads on this problem so use the search feature and you'll find it..
https://www.thirdgen.org/forums/body...alignment.html
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
But yea, I will also be trying both adjustments as it doesn't line up at the bottom and there is a big gap up top (no leak though) and now thanks to me, its a little off center...
Car: 85 trans am
Engine: 5.0 carbed
Axle/Gears: 9 bolt
Thank you for all the help and links!!
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 700 r4
Axle/Gears: 323
Car: 1992 Camaro RS Heritage Edition
Engine: 305/5.0L
can't wait to try this out. my spoilers are rubbing and i'm too scared to even open my trunk. thank god for fold down seats.
Engine: 305/5.0L
worked awesomely on my driver side.. but my passenger side was hit in an accident in the previous years.. i was wondering if any one knew and tricks to the autobody trade that i could just fool the eye with the spoiler/hatch aligning to the rear quarters.
PLEASEEEEEEEEEEE SOMEONEEEE
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Pics would help but if it's got previous damage then that may need to be repaired properly to get correct alignment.
Engine: 305/5.0L
passenger side
http://img.photobucket.com/albums/v2...sengerside.jpg
top view
http://img.photobucket.com/albums/v2...maroass2-1.jpg
driver side
http://img.photobucket.com/albums/v2...ch/maroass.jpg
rear end
http://img.photobucket.com/albums/v2...h/maroass4.jpg
i bought a new bumper, but i'm more worried about how much it sags on the passenger side. i'm not even sure how much of it is bondo.
i'll get better pictures in the next few days.
top view
driver side
rear end
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
passenger side
top view
driver side
rear end
top view
driver side
rear end
Engine: 305/5.0L
i did use silicone.. and i do need to re-do it anyways, as i've left a leak in it. aside from that , once you take the deck lid off there's only so much room you have to tweak it.. and i gave it all the forward slack it had, glued and torqued it down. and then i loosened the hinge to body bolts to see if i could get some slack. not much there either.. i'm worried to touch the latch to glass bolts. they just worry me. thanks for the reply, by the way.
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
No problem Josh, glad to try and help. There should be enough adjustment in the hatch to glass bolts/nuts. Are you adjusting it with the lift/supports removed? Try and remove them then aligning the hatch before you disassemble everything again. It should move some. GM recommends leaving the hatch short of the quarters 1/16 of an inch I believe, I'd try more like 1/8. I've quoted the repair manual on another thread but can't remember right now. Some of these new lift/supports are a lot stronger than the old OEM ones.
BTW you could cheat the spoiler back on the right side some to make it look better.
Engine: 305/5.0L
yeah i had everything disconnected. the hatch dampers are OEM.
what do you mean cheat the spoiler? i'm so ocd when it comes to symmetry. lol
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
That right side is a long ways off. It could be in the glass to hatch still, that would be my first guess. Double check that first then you may want to check to see if the spoiler on the hatch will move forward some on the right side. There are no pics from underneath the hatch so I can't tell about that. The right piece could be moved back on the quarter some even if you have to elongate the holes some. I know there will be a gap between the quarter and spoiler piece but it will be less noticeable that the misalignment between the spoiler pieces.
Street Lethal
Apr 30, 2019 12:14 PM
