Dash bulbs and photoshop
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I am in the process of replacing the bulbs behind my gauge cluster, but cannot find the bulbs attached to the grey thing ANYWHERE. I tried AutoZone, Pepboys, and Trak Auto. They all have just the bulbs. Is there any way to get the old bulbs out and put the new ones in the housing? I don't wanna break anything.
Also, I finished my speedo white faced gauge, but when I printed it, the numbers had rough looking edges. How can I fix this with photoshop? I printed it on photo paper at 300DPI. Any help is appreciated. Thanks again.
1992 Camaro RS
5.0L TBI
K&N Airfilter and ready to take on the world!
My 1992 RS
1992 Camaro RS
5.0L TBI
My 1992 RS
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey man, I really do not have any helpful advice for you, but the car looks good!
Later
MIke
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Later
MIke
Car: 4
Engine: 6
Transmission: 5
They just pull out of the sockets...
{edit} bulbs are # 194
ICON Motorsports
[This message has been edited by RB83L69 (edited August 04, 2001).]
ICON Motorsports
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Yea like RB83L69 said. Just pull off the bulb from the sockets. And then put the new bulb on and squeeze on the metals parts. And right there you got the new bulbs with attachments. Cause from what I remember its like $5+ for the bulb with the socket. While its like 1-2 bucks for 2 194 bulbs.
Chris
91 RS 305 TBI
Eternal Rev
I am sad
my car is hurt...
Chris
91 RS 305 TBI
Eternal Rev
I am sad
my car is hurt...
Car: 1986 IROC-Z
As far as your Photoshop question is concerned...
How did you go about getting the image to 300 dpi? Did you actually scan/create the image in that resolution, or did you just increase it using the "Image Size" dialog? If you did it the latter way, then it'll come out all jagged. Another thing: make sure that the "Resolution" field in Image Size says "pixels/inch" and not "pixels/cm." Hope that helps.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
You can also(if you created) use the sharpen feature from Photoshop on the scaned image, then reprint. Also make sure that as blue86 said the resolution must be set right.
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels,new charcoal & gray interior including seats and door panels, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Morgan_Andre@hotmail.com
Axle/Gears: 3.45, 3.27, 3.27
As others have already said, just carefully replace the burned bulbs in the plastic bayonet sockets. But test them with a Multi-tester. I had to try a couple of times to get it to make contact correctly.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
I just cut the wire leads off where they were on the socket and then pulled the bulb out, and put new ones in, bent their leads over the metal part and sodered them.
90 IROC 5.7l (L98)
ram air, K&N's, air foil, full exhaust
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
90 IROC 5.7l (L98)
LIKE A ROC
Car: 1989 IROC-Z
Engine: 383 stroker
Yeah, thats what I did, they all work fine. Thanks guys.
1992 Camaro RS
5.0L TBI
My 1992 RS
1992 Camaro RS
5.0L TBI
My 1992 RS
