Pics Needed of Ram Air II Hood on Firebird
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Hey guys trying to decide on a hood to go with. Im pretty much leaning toward the Ram Air II but was wondering if anyone can post a few pics of it on a firebird.
Ultra Blue or on a Vert would be a plus.
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: Pics Needed of Ram Air II Hood on Firebird
The only thing I don't like is mine isn't the best quality. It doesn't fit (line up) that great, but I bought it from an individual at a good price so can't complain. If you have the ability get it from a good source. Other then that its a great hood!
Engine: 5.7 L98
Heres it on my TA. I love this hood, changed the car completely.
Attachment 259024
Attachment 259025
Attachment 259026
Attachment 259024
Attachment 259025
Attachment 259026
the hood opens the same? i dont want to use hood pins or anything
It could use a hood spring like stock, because it is picky on how it opens. Mine anyways, but most fiberglass hoods are like that since there isn't a provision for the spring. It still opens with the latch and everything like stock though. I just plan on getting the pins, but that's just me.
Engine: 5.7 L98
whats the advantage of the pins? obviously the disadvantage is they look retarded
Well everyone views them differently, I personally think they look good when done right. Plus you can get locking ones, which then means you can completely remove the stock latch without worrying about getting your hood opened by someone unwanted.
Engine: 5.7 L98
Engine: 5.7 L98
eh, i guess the hood pins dont look that bad. how exactly do they install and what are they taking the place of?
for me i went ahead and took out the latch and all, i didnt see a reason to have the pins and the latch. as far on installing them. all i had to do was drill a 1/2 inch hole in the rad. support and line up the hood and drilled the hole there. on the hood side there are metal plates that just screw down to dress up around the hood pins.
Engine: 5.7 L98
so anyone can come and open up your hood at any time?
car looks real good like that, but that looks like the 94-97 ram air hood made for your car. i was looking at getting one for mine like that but didnt think it would look all that great, but seeing it on yours looks like i was wrong
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
IMHO the Ram Air I hood looks best on the pre-91 Firebirds. It lines up with the body lines much better than the Ram Air II hood. At certain angles, the Ram Air II hood doesn't look right on the car, but on the 91-92 bodies it looks spectacular. I have a Ram Air I hood on my car and the only complaint I have is that it isn't functional. It could be made functional, but it would take some work whereas the Ram Air II hood is made functional easily. It all depends on what you're looking for, aesthetics or functionality along with how much money you are willing to spend.
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
see my gta sig for full pics..(:
1992 Trans Am
May 10, 2023 07:19 PM
