Idea: Naca ducting to cool front brakes
Subscribe
Oct 15, 2001 | 10:50 AM
here's the scoop, I'm thinking of getting a small set of NACA ducts laid into the front fender when the car is painted in spring. it would be below the body crease, and color matched so it didn't stick out. I autoX the car and drive at the limits of the brakes sometimes...
Has anyone done this? any advice? Tips? yeas or Nays?
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
Reply 0
Oct 15, 2001 | 01:53 PM
that would be very cool looking. i would love to do something like they do in nascar with the window vents. i think that would be cool. is there anyone that can make a pic to see what it looks like?
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Reply 0
Oct 15, 2001 | 03:23 PM
On a fourth-gen it looks like this:
-Matt
Reply 0
Oct 15, 2001 | 03:51 PM
I think that pic pretty much seals it up. I'm in!
Reply 0
Oct 15, 2001 | 08:09 PM
I believe the 91-92 Firebirds with the ground effects had ducts infront of each front wheel to direct air towards the vented disc brakes. They were located underneath the body right infront of each wheel. please correct me if I'm wrong.
1991 Pontiac Firebird V6 W68
Pioneer DEH-7000R, Pioneer 6X9 4way/4X6 2way speakers, MTX 250watt amp, MTX 400watt sub, custom intake, Flowmaster dual exhaust 80 series, PIAA HID headlamp conversions, custom tail lamps(regular F-bird but amber is now red), many more to list...
Reply 0
Oct 15, 2001 | 08:18 PM
91-92 Camaros with ground effects had those in front of the front and rear wheels, and they were fully functional...
arthur@thirdgenfbody.com
www.thirdgenfbody.com
1985 IROC Resto underway
Reply 0
Oct 16, 2001 | 10:35 AM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Thirdgenfbody.com:
</font>
Actually they aren't functional, they are purely cosmetic. The only thing they route air to is the front of the tires.
-Matt
Reply 0
Oct 16, 2001 | 03:28 PM
I have a 91 Firebird with gfx, but as far as I can tell, any ducting that may be integrated is non-functional. It seems that it could be made functional though . . .
Reply 0
Oct 16, 2001 | 04:18 PM
I've seen pics of someone that used (ducting) hose and attached the one end for the intake of air behind the lower air dam (the one that gets bent and misshaped but speed bumps) with some holes cut into it. Then fed the hose over to the brakes. I hope that makes sense to everyone. It's something that I've thought about doing myself, just haven't got around to it.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for front and rear LCAs and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, Corvette Servo, TransGo Shift Kit, Corvette 2000 Stall, TruCool LPD tranny cooler, T-tops.
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
Reply 0
Oct 16, 2001 | 04:58 PM
Were did you find that fourth gen pic? I want to do that to mine, and I couldnt find anyhting on it.
Chris
-94' firebird formula(I used to have a 91,thats why im on this site)
-All stock
-Future mods= borla cat back exhaust, K&N Intake, and Hypertech programmer
Reply 0
Oct 16, 2001 | 05:12 PM
IROCKER, I think these pictures depict what you are describing:
Chris, the link with more information is here:
http://home.earthlink.net/~jonaa/Brakeducts.html
Reply 0
Oct 16, 2001 | 08:50 PM
What happens if you hit the air dam though with that setup? won't it knock the tubes off or bend then?
Reply 0
Oct 17, 2001 | 12:31 PM
Quote:
<font face="Verdana, Arial" size="2">Originally posted by lineb:
What happens if you hit the air dam though with that setup? won't it knock the tubes off or bend then?</font>
I doubt it. The ducts are rivetted to the airdam and the tubes are flexible, but still securely fastened to the duct. There shouldn't be any problems. I've also seen people use fourth-gen exhaust tips as ducts. They were placed at each side of the airdam. This might work better for you if you are concerned you would damage the ducting in the airdam.
-Matt
Reply 0
Oct 18, 2001 | 08:37 PM
When I moved my radiator and had to remake my airdam, I incorporated some scoops. For me they run up into the engine bay, but you could run than to the brakes just as easily. I just used cheapo home depot ducts and scoops..maybe someday I'll redo it better.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Reply 0
Oct 19, 2001 | 08:22 PM
Behind where the ducts are on the blue SS, there seems to be PLENTY of room on my 1986 Z, I'd say this is pretty much foolproof.
Matt86Z
Reply 0
Subscribe
