I bought an overhead console for my Bird
Old Oct 20, 2001 | 10:14 PM
Brent Swan's Avatar
Hello all..Just stopped by,haven't been in here for awhile..This board still has the most current and best information on the web..Hats off to everyone!!..Now to why i posted this topic..I recentely purchased an overhead console for my T-top equipped Firebird..it never had this equipped...sooooo..what actually needs to be done to my car to get it ready for the console install?...i am also thinking about purchasing the new ABS T-top board..is it possible to mount the console to the ABS board without having it look so out of place?..any information or installation hints on the overhead console or the ABS headliner product would be greatly appreciated..Thanx!
Old Oct 21, 2001 | 11:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the tech board. An article appears there which will facilitate the mounting procedure. By the way, there are two versions of the overhead console: the t-top version and a couple version. They are not interchangeable.
JamesC
Old Oct 21, 2001 | 07:29 PM
Brent Swan's Avatar
Yeah,Thanks for letting me know about the tech article on how to install the overhead console..it will realy come in handy..now about my other question...has anyone had experience mounting their console to the new ABS headliner boards?..and how does it compare as far as looking stock versus being installed on the fiberboard type headliner?..Thanx!
Old Oct 22, 2001 | 12:13 AM
Tonyrodz's Avatar
Transmission: auto
Well, I installed my overhead console in my T/A(t-tops) using a t-top board from a car that didn't originally come w/one--I had to cut a hole in the board to make it work--for wires-pins etc-so I think you might have to do the same thing--not sure if you'd want to tho!!
Especially in fiberglass!!
[This message has been edited by Tonyrodz (edited October 21, 2001).]
Old Oct 22, 2001 | 06:56 AM
JamesC's Avatar
Tonyrodz is correct. If you want the console, you'll have to do some cutting. I have no experience with the ABS board, but I assume it's a fiberglass version of the original. Might I suggest that you use the orginal headliner to make a template. I did this with my headliner "in car". I simply made a 'pattern' from the console itself and cut the holes very carefully (cut X's in the fabric so that you can tuck the flaps under the headliner). I wasn't gambling much, however, because I was only a few weeks away from redoing the entire interior.
JamesC
Old Oct 22, 2001 | 11:28 AM
Brent Swan's Avatar
Thanx again for all the helpful information.I am still undecided exactely which way to go.Should i go with the "regular" type headliner board or should i maybe purchase the ABS one.My headliner at the moment is trashed,as we speak the headliner material is sagging and the actual material that the headliner board is made up of is falling all in my seats and stuff.Sort of makes me feel bad for my car..sniff..As soon as i finish typing this i will be on my way to remove that board,was gonna wait till i made up my mind about which way to go,but it really don't need to fall apart any further.Right now the ABS one seems to be the way to go.Anyone out there have any experience with the ABS one?..Thanx!
Old Oct 22, 2001 | 01:02 PM
Tonyrodz's Avatar
Transmission: auto
Have you thought about trying to re-cover the original headliner? All you'll lose is the time spent and the headliner material--instead of the $150 for the new headliner!!
I'd rather cut the old one instead of the glass one.
Something to think about
Old Oct 22, 2001 | 04:26 PM
Brent Swan's Avatar
I actually thought about recovering my old one,but its too far gone.The headliner material is trashed.The owners before me must have thought that ciggerette burns where cool,so they put like 10 of them into the headliner.Bad thing is, it not only burnt the material it actually burnt the headliner board itself.Plus the material that the board is made up of,is actually decaying...i believe its time for a replacement.I said earlier that i was gonna remove it and i did,it now lays in my yard in many pieces,it started falling apart when i was removing it,so i guess its best to go back with a new one.
aaron7
Aug 17, 2016 06:02 PM
86IROC112
Sep 7, 2015 01:37 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
TheJoeY88
Aug 13, 2015 06:51 PM
