Taking apart front turn signal lense assembly
Old Nov 2, 2013 | 09:02 PM
Bruce91RS's Avatar
What is the easiest way to remove clear lense from black plastic housing? I need to clean and polish mine. Thanks.
Old Nov 2, 2013 | 09:10 PM
Joe Tag's Avatar
Re: Taking apart front turn signal lense assembly
I thought of doing this myself.(mine has yellowed bad on the inside) I really don't think there is a way to do it without ruining them. I'm just gonna break down and buy new ones.
Old Nov 2, 2013 | 09:32 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
There is an extensive thread but IDK how to link from my phone.
I know articwhitez did a how-to with great step-by-step pics & info.
IIRC
Dremmel with a super fine cut off.
Sorry but you will have to do search.
( edit )
Title & original poster--
Cutting apart and cleaning your turn signals
articwhiteZ
Old Nov 2, 2013 | 09:44 PM
Joe Tag's Avatar
IIRC
Found the thread you mentioned. Apparently, the lens is just glued where it butts up against the back housing and not on the inside of the lip. This looks do-able.
https://www.thirdgen.org/forums/auto...aning-you.html
Old Nov 2, 2013 | 09:59 PM
Car: '87 Camaro
Thats it!
Sorry I couldnt link.
You can do it... I believe in your abilities...lol...
Dont forget the blade // wheel artic mentions. Aparently its a very fine tooth so as not to chip and fracture the plastic.
Good luck
Old Nov 2, 2013 | 10:17 PM
Joe Tag's Avatar
Oh, so my skills are that apparent, even over the web? My only concern in doing this before was whether or not it was glued on the inside of that lip. The straight in cut is no problem, but a cut 90* from that would be impossible without damage of some kind.
I just got a craftsman all in one cutter (like a dremmel on steroids) and been itching to try it out. I think I'd try the small cut off disks first, have like 50 of them, and a way finer cut than that saw blade. I have nothing to lose really, planned on replacing them anyhow.
Old Nov 2, 2013 | 11:00 PM
Car: '87 Camaro
Ours are so old & have broken mounting tabs, so the Christmas list gets added to!! Lol!!
I will R & R the tail lights in spring tho.
LMK how the craftsman works out. IDK which to get
Dremel or craftsman.
Old Nov 3, 2013 | 05:03 AM
Bruce91RS's Avatar
Thanks for the tips.I'll let you know how it goes.
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
