GTA seats or 4th gen seats?????
Old Dec 9, 2001 | 12:40 PM
89 4Mula 350 Tbi's Avatar
Hey guys/girls i got a question i have and 89 Formula with no power seats; now if i get leather 4th gen seats or gta seats that have a power drivers seat how would i go about hooking them up. Also ne one know where i can find a set for a resonable price and a rear seat in leather for a resonable price. Also on my seat that i have now i can control moving it back and forth and till the back rest but there is still one more lever and i have no clue what it does. Thanks in advance ppl.
Old Dec 9, 2001 | 04:21 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
I think you will find the third lever will tilt the entire seat assembly.
As for power seats, if it only the drivers seat, you will need 12 volts, (constantly hot) for the seat, and of course a ground.
If you get the GTA or any other seats with power lumber and inflatable bolsters, you will have to get the wire harness and pressure / vacuum line that goes from one seat to the other (under the carpet) as the pump is mounted under the drivers seat, but still operates the passenger seat. The switch on the passenger seat operates the pump and valving under the drivers seat for its own use.
Hope this isnt too confusing.
Leather seats can be had typically for $400 up, in good condition. Check with speciality dismantlers, or possibly ebay.
I bought a full set (front and back) of full power leather 4th gen seats for my GTA in mint condition for $400.
Cheers
Richard
Old Dec 9, 2001 | 06:03 PM
Thanks for the info. Where did you get yours? And do the rear seats of a fourth gen bolt in directly in our cars. thanks.
Old Dec 9, 2001 | 06:11 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Junk yards seem to have alot of 4th gen seats available. You just have to go to a bunch to see which is in the best condition.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
Old Dec 9, 2001 | 06:24 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
4th gen seats, front and rear bolt in perfectly into a third gen. No mods required.
Cheers
Richard
Old Dec 10, 2001 | 09:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Unless you want to take advantage of the power lumbar and bolsters. Then you need to tap into the +12 volts, as well as run wires & air hose between the two seats. Instead of clamming up $100+ for the GM harness, I made my own and bought some vacuum hose for the air pump. Works like a champ and cost me about $5.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 10, 2001 | 10:59 AM
Drew's Avatar
Everything listed above is correct. Power and ground, as well as the added lumbar wiring which just goes from one seat to the other.
I have a set of 4th gen seats in leather I'm looking to get rid of, but I'm not really interested in shipping them.
Drew
predatorman@hotmail.com
83 Camaro 5.0L *1995-98*
87 Iroc 5.7L
91 Formula 5.7L 14.3@98mph
91 RS Convertible 5.0L
91 Firebird 3.1L 17.00@82mph *Gtech*
92 S10 2.8L
98 Grand Am GT 3100
Parts for sale
Old Dec 10, 2001 | 02:42 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you remove the seats from a 3rd gen, the power seat wires go from under the seat & simply plug into a panel on the left side above your kick panel. I simply followed the wires around & unplugged. The ground wire attaches to the body close to the thresh-hold. this does a nice clean job and it is designed to take the load.
4th gen might be the same but I do not know...
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
Frozer!!!
Jan 19, 2024 04:55 PM
lee01
Apr 9, 2016 01:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
