T Top problem
Old Feb 13, 2014 | 07:43 PM
karllo's Avatar
Car: 87 GTA
Engine: 350 Tpi
Transmission: 700 R4
T Top problem
Hi, i was searching for a long time whats is name and where could i buy this...
im searching the wide ruber that is glue on the top of the glass.. HELP!!!
thats for a 87 trans am! Thanks!
Old Feb 14, 2014 | 07:24 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: T Top problem
on the outer edge of the t-top? I believe that was called the drip edge trim, or something along those lines. Someone on here was selling some a while back, may have been 1A auto, can't remember.
Old Feb 14, 2014 | 07:25 AM
Car: 1983 Z28
Re: T Top problem
yup, here are some links:
https://www.thirdgen.org/forums/body...drip-edge.html
http://www.hawksthirdgenparts.com/pr...tic-Style.html
http://www.firebirdcentral.com/category_s/456.htm
Old Feb 14, 2014 | 09:51 AM
karllo's Avatar
Car: 87 GTA
Engine: 350 Tpi
Re: T Top problem
Not the outer drip edge , im talking about the one thats on the glass ...the one upper the outter drip edge.
Old Feb 14, 2014 | 10:39 AM
82tarecaro's Avatar
Re: T Top problem
That's not replaceable. You can paint it and it will look like new. Use some SEM Trim black, a good primer for plastics, and adhesion promoter.
Old Feb 14, 2014 | 04:06 PM
karllo's Avatar
Car: 87 GTA
Engine: 350 Tpi
Re: T Top problem
My t top fall on the ground and an inch of this moulding have broke..need to replace it..something should exist that l could put instead...money is not problem for me...
Old Feb 14, 2014 | 04:08 PM
82tarecaro's Avatar
Re: T Top problem
If money is no issue, look for a replacement t top. There are plenty on Ebay and it is the easiest way to fix your problem.
Old Feb 14, 2014 | 04:22 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: T Top problem
The end piece is SMC fiberglass and is bonded to the glass. Its not a replaceable part. You could repair the chipped edge with a fiberglass repair kit but its not really worth the trouble given how inexpensive used T-Top hatches are.
Old Feb 14, 2014 | 04:28 PM
karllo's Avatar
Car: 87 GTA
Engine: 350 Tpi
Re: T Top problem
I already have a replacement t top but i want to repair my original...the piece is not looking like firberglass...its more like black fritable rubber
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
