do thay make replacements parts for this
Car: 85 iroc z
Engine: air for now
Transmission: none
So I was taking my interior out to redo it over winter I know I had to do some floor work but when I pulled up The carpet I seen that the pice that the seat bolts to is rusted pretty good so do they make a replacement part for this I've called around to see if I could get a donor floor pan but no body in my area wants to cut up there parts car
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: do thay make replacements parts for this
Hello SS237gogeta
We have the pans, but the seat mount brackets are not available as far as we know.
http://www.classicindustries.com/shop/search/?q=C12179
http://www.classicindustries.com/shop/search/?q=C12180
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
May have to find a donor vehicle in a junk yard or one that someone is parting out and have them cut that section out for you.
Car: 89 IROC-Z
Engine: 89-TPI 5.7
I'm replacing one of my seat cross braces. I picked up a donor car and got the piece of floor and the cross brace then scraped the rest.
Car: 85 iroc z
Engine: air for now
Transmission: none
That sucks I hope one day somebody makes them I guess my project will be on hold until I can find a donor car thanks for the info
Car: 89 IROC-Z
Engine: 89-TPI 5.7
I would go to a junk yard with the tools I would need and get one. I just lucked up and found a parts car that had it. The junk yard would be your cheapest bet.
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
I'm pretty sure Hawks Thirdgen cuts up parts cars they have, you just have to call them and put in a custom order. I saw one guy order the top half of a windshield and A-pillars from them.
Engine: 5.0 EFI
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
It doesn't look that difficult to make them, worst comes to worst. I mean, if you have the skills to put in a floor pan, cutting up some square stock and welding two studs to face upwards would be cake.
That is, if there's not some important piece of information I'm missing.
