fiberglass hood problems
Old 11-20-2014, 04:14 AM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
last year i managed to pic up a ram air 2 hood for my bird for 60 bucks off a junked car at pick a part but ive been living with this dilema . the hood doesnt fit properly especialy on the fenders if you look at it from the side it looks like if you squezed a playing card on each end and it bowed up ya know it doesnt fit the curves of the fenders . and do it seems to sit slightly crooked like a few centimeters of the center line which may be do to my hood pines and were the holes are dilled but the biggest thing is it doesnt sit flush with the fenders and the nose . any input on what could be the problem thanks
Old 11-20-2014, 09:33 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: fiberglass hood problems
Have you tried closing the hood without the hood struts attached? Are they providing an upward push while the front is latched?
Old 11-20-2014, 09:40 AM
mikey8494's Avatar
Axle/Gears: stock
well when it was on the other car also a 91 92 car the hinges wernt bolted to the body you could lift it off so i dont know what that means
Old 11-20-2014, 09:48 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
pics would help
i think it's the nature of the beast. glass hoods generally don't fit as well as a good steel one. JMO.
do you still have the rubber pieces on the inside of the fenders where the hood shuts? a new one or a possible shim under it might help push a low spot up. just gotta fudge em around.
PS, most body guys hate messing with glass hoods. just ask one.
Old 11-20-2014, 08:32 PM
mikey8494's Avatar
Axle/Gears: stock
yea the rubber pieces are there but they dont even come down close to them i can stick my finger between the fender and the side of the hood thats how much its bulging up
Old 11-20-2014, 09:56 PM
Night rider327's Avatar
Car: 1988 Camaro
I have seen hoods where we had to grind out/drill out the holes in the hinges more so we could adjust hood back more to fix probs sorta like yours.
What about the rubber bumper stops up front? Have you adjusted those all the way down, or removed them?
Still using a spring up front? My dad has a RAII hood from the no longer around ramairhoods.com site and his fits great everywhere but the front at the latch and spring. With the spring installed it pushed the whole hood up from front to about 2/3 of the way back along the sides. Removed spring and hood fit down perfect.
Old 11-21-2014, 01:13 AM
mikey8494's Avatar
Axle/Gears: stock
i removed the spring and it sits alot more flush agianst the nose but still looks like the front and back are squeezed together causeing it to bow up in the middle
Old 11-21-2014, 01:26 AM
Car: 1988 Camaro
Have you tired to adjust the hood/hinges back? If so, you may have to do like I mentioned earlier and drill out the adjustment slots bigger so you can move hood back more
Old 11-21-2014, 02:01 AM
mikey8494's Avatar
Axle/Gears: stock
ill try that if anything ill just save up for the vfn 5 inch ram air set up they sell
Frozer!!!
01-19-2024 04:55 PM
Street Lethal
04-30-2019 12:14 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
sweet_87_iroc
03-27-2016 04:05 PM
Bert87
08-23-2015 03:50 PM
Quick Reply: fiberglass hood problems
