Hood cracks, repair or replace?
Old Feb 13, 2015 | 10:36 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
I've got a 86 GTA hood on my 82 and due to improper storage while off, I have seviral cracks in the hood. So, repair, and how, or replace?
Old Feb 14, 2015 | 09:57 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Hood cracks, repair or replace?
Cracks? It's a steel hood, where are the cracks?
Old Feb 14, 2015 | 12:51 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
There is 4 over them, this is the biggest.
Old Feb 14, 2015 | 01:15 PM
stealtht/a's Avatar
where are the cracks exactly? Can't tell with that close up. Generally I would say junk it and get another since the steel TA hoods aren't that hard to get. The hood has a support structure underneath so if it flexed enough the top panel cracked, it's probably pretty far out of shape. if it's a small area mid panel, weld it and level with filler.
Old Feb 14, 2015 | 01:29 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
Here is the entire hood, you can see all 4 cracks, they aren't super huge. They may just need a filling of some sort.
Old Feb 14, 2015 | 01:37 PM
stealtht/a's Avatar
Hard to tell in pics, but is it buckled in the middle of the crease? If so, lots of fairing work.
Maybe some cracks are just paint bubbling? Can you see the creases/cracks on the back side?
Old Feb 14, 2015 | 01:46 PM
Transam.82's Avatar
Car: '82 Trans Am
Engine: 388 5.7L V8
Transmission: T-10
I checked the paint, some of paint bubbles/peeling but 4 are cracks. Also no buckeling and not visible through the hood. Bondo or JBweild might fix it. Is there a such thing as an unsafe hood?
Old Feb 14, 2015 | 01:52 PM
Joe Tag's Avatar
Looks like cracks in body filler to me. Hoods are the worst to work on. Long flat surface right at the perfect angle in the drivers seat to see any imperfections. I'd say scrap it and find a good replacement.
Old Feb 14, 2015 | 02:45 PM
stealtht/a's Avatar
If you can't see it on the backside, it's not a crack in the steel. It's just thin sheet metal, the structure underneath is what gives it any strength. I think you just have cracking/ buckling bondo and paint. Grab a grinder or sander and you can find out real quick.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Aug 6, 2015 04:15 AM
