Our rust prayer has been answered!
Old Jun 27, 2015 | 08:37 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
$6-8
If you "leave" it on their it turns white and hardens. But can be remedy-
Old Jun 28, 2015 | 08:54 AM
82tarecaro's Avatar
Re: Our rust prayer has been answered!
Naval Jelly has been around forever.
Old Jun 28, 2015 | 09:10 AM
RustyFormula's Avatar
Car: 91 Firebird Formula
Engine: 5.7
FYI: Naval Jelly is acid-based and meant to be rinsed off and neutralized with water.
I doubt any post-application coatings will adhere if you don't rinse the jelly off first.
Old Jun 28, 2015 | 10:24 AM
Car: 88 IROC-Z
I just stumbled onto it this month at my second job (Lowes)-
Yes, I know and mentioned that.
Old Jun 28, 2015 | 10:40 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Old Jun 28, 2015 | 11:44 AM
Billgluckman's Avatar
Wire wheel anyone?
Old Jun 28, 2015 | 12:25 PM
Car: 88 IROC-Z
Originally Posted by Billgluckman
Wire wheel anyone?
Yes I know, but that takes "work" (doing it the manuel way). Us 3rdgen men (those who have concord LTs) are already tired from earning a living the "manly" way. I wanted something that required little to no effort. Similar to have someone else doing the work.
Old Jun 28, 2015 | 01:39 PM
82tarecaro's Avatar
There is no shortcut to removing rust. That naval jelly works for slight surface rust, but will not put a dent into anything deeper. There are better products out there. But in the end rust removal is still a ton of work.
Old Jun 28, 2015 | 01:40 PM
Car: 88 IROC-Z
There is no shortcut to removing rust. But in the end rust removal is still a ton of work.
agreed-
Old Jun 28, 2015 | 09:57 PM
I sweat all day long turning wrenches for a living. I wish there was an easier way, but there isn't. Honestly for the wait time involved once you apply these things, you could have removed it with a wire wheel. That is if it's save-able at all.
Old Jul 1, 2015 | 01:28 PM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
If the metal has been contaminated deep into it's pores the rust will comb back, wire brushed or not.
Cutting the rust out and welding is the only thing I have found effective.
Fireslash
Apr 11, 2016 06:43 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
