Outside of window getting scratched by these. Where do I find them?
Old Sep 14, 2015 | 01:24 PM
SPEEDY Z28's Avatar
Hi my 84 Z28 has 3 or 4 of these rubber guides or something along the outside of the window. Does anyone know what they are called, where to get them, or how to fix it? Mods please move if I'm in the wrong forum.
Old Sep 14, 2015 | 02:23 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Outside of window getting scratched by these. Where do I find them?
http://www.1aauto.com/1982-92-chevy-...=309242&y=1986
looks like you need inside also
http://www.1aauto.com/1982-92-chevy-...=329665&y=1986
or
http://www.1aauto.com/1982-92-chevy-...=476084&y=1986
Old Sep 14, 2015 | 04:10 PM
SPEEDY Z28's Avatar
Are the little rubber pads down inside the door actually part of the sweep?
Old Sep 14, 2015 | 04:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Are you talking about the window guides?If so IIRC they may be part of it I'm not 100% certain, if not they are available
http://www.1aauto.com/window-guide-p...=261199&y=1986
Those are not rubber, they are felts
you need a better pic of your door,it seems that theses are missing also
http://www.hawksthirdgenparts.com/88...-reproduction/
Old Sep 14, 2015 | 06:13 PM
SPEEDY Z28's Avatar
It's the rubber/plastic pieces circled on the outside of the window. I have the felt window guides on the inside of the window. I'll try to get a better pic when I get a chance
Old Sep 14, 2015 | 07:04 PM
gt4373's Avatar
Transmission: 5-Speed Manual
I've Never Seen Those On A Third Gen.
Old Sep 14, 2015 | 07:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
I've never seen them before,I thought you were talking about the outer window sweeps, That's a CHEAP FIX that didn't work.do yourself a favor and do it right
Old Sep 14, 2015 | 10:30 PM
SPEEDY Z28's Avatar
I don't know. It looks like it's supposed to be there. The very front one still has some felt left. There are 3 on the driver side outside of the window.
Edit: it's probably the window guides you already posted. I was thinking you posted the ones for the inside.
While we are on the subject, does anyone know where to get the triangle filler pieces and what they are actually called?
Old Sep 15, 2015 | 07:12 AM
mantaguy's Avatar
Engine: 5.0 EFI
Same place you get the window sweeps
http://www.1aauto.com/1982-92-chevy-...=260240&y=1986
Old Sep 15, 2015 | 09:59 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Don't count out the inner guides (#18 in diagram) if you haven't pulled them for inspection. They tend to wear unevenly and are the most common cause because the windows weight and also adjustment causes a good amount of pressure on them. Another way to tell is if the edges of the inner pads match up with the scratches of the window.
Old Sep 15, 2015 | 04:07 PM
SPEEDY Z28's Avatar
I believe I'm needing the piece those attach to. This is a pic of one. Actually I believe it's #92.
Old Sep 15, 2015 | 05:34 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Unless the door panel is off, or even then I tape a piece of thin string to the tiny wrench I use for that and a loop on the other end that will slip onto my wrist. There is not a lot of room to work so its very easy to drop/slip from your fingers and down it go's.
That's unless you don't mind removing the panel to retrieve it or hunting for it even with the panel off.
A lot of guys don't even have a wrench that small so dropping one down inside the door sucks.
A temporary fix is thin adhesive felt pads.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
pfsteichen
Feb 9, 2016 06:59 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
