Replacement headlight options
Old Dec 1, 2015 | 07:44 AM
yessahbud's Avatar
Sorry for posting this. I'm sure there has been a ton of questions about this and I did do some searching, but not finding what I'm looking for.
The stock headlights are horrid right now. It might be brighter if I taped a flashlight to the hood. We have an 88 iroc and want to know what the easiest option is for replacing or upgrading the headlights.
Would really like something plug and play, but I could do minimal wiring if I had to.
Anyway what are people using for direct replacements that look new and clean and are easy to install? Thanks!
Old Dec 1, 2015 | 09:37 AM
yessahbud's Avatar
Re: Replacement headlight options
Looks like Sylvania makes direct replacement bulbs/headlight. The silverstar. Are those an alright bulb to use? I got them in my tacoma a while back and wasn't impressed with the light they put out, but I want a direct replacement that's better than stock so.... :/
Old Dec 1, 2015 | 10:27 AM
Degweiser's Avatar
Car: 1992 camaro z28, 1988 camaro sc
Engine: 350 tpi, 305 tbi
Transmission: t-5, t-5
i was looking at these, anyone tried something like this?
http://m.ebay.com/itm/82-92-Chevy-Camaro-EURO-HIGH-LOW-x4-Headlight-Adapter-/351127029140?nav=SEARCH
Old Dec 1, 2015 | 11:37 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I have the Sylvania Silverstars on my car. They work great. I even put them on my S.U.V.
Old Dec 1, 2015 | 12:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
X2.
JamesC
Old Dec 1, 2015 | 12:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
82 92 Chevy Camaro Euro High Low x4 Headlight Adapter | eBay
Didn't look at the actual ad, but I bet it's a kit to do what I did years ago. I got 2 replacement hi/lo beam lights(aka the outer lights) and plugs from a junkyard. I used the JY bulbs to replace the inner hi beam only bulbs so I now have 4 lo beam and 4 hi beam lights. Then wired them up with relays so they get power directly off the battery, instead of through the headlight switch. Plenty of light now in front of the car, even better than my wife's '12 avenger. For good measure, I also picked up a couple of aftermarket fog/driving lights from another junkyard and replaced the 55w H3 bulbs with 100w H3 bulbs. I can drive just fine at night with just those on, but with everything on, it's almost as good as driving in daylight. I really miss it when I park the car for the winter and have to drive my S10 with its stock headlights.
Old Dec 1, 2015 | 02:06 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
+1 on the sylvania silver star headlights . also correct adjustment of the headlights is critical
Old Dec 1, 2015 | 03:24 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
http://skinnyboylighting-com.webs.com/
Old Dec 1, 2015 | 05:05 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I have the Xtravision's and they work for my DD city driving.
I will most likely try the Silverstar's when the time comes.
Old Dec 1, 2015 | 07:19 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
What you posted up is similar to what I did.
Easiest option is to buy 4 of the housings only and use whatever h4 bulb you want.
The stock wiring will plug directly into h4 bulb, but you will need to swap the wires in the plug. Search h4 adapter on here to see what to swap
Old Dec 5, 2015 | 09:33 PM
kyrenegade's Avatar
Car: 91 Camaro Z28
Axle/Gears: 3.42 Posi Disc
Truck Lite and GE Lighting have a LED replacement for the quad lamp high beam, low beam system (165MM). They are out of reach for me because of the cost.
Here is a link I found=http://www.truckinginfo.com/channel/products/product/detail/2015/05/truck-lite-releases-4x6-led-headlight-system.aspx
Old Dec 6, 2015 | 09:16 AM
Jowens's Avatar
Sorry to post on this discussion but using my phone, I can't figure out how to post a new question without getting into some one else's. Anyway. I bought an 89 iroc with350. Great shape low miles. Can I change the body kit to a 91 or 92 body kit.
Old Dec 6, 2015 | 09:22 AM
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
Yes. Keep in mind that the 91-92 has a different rear bumper too
Old Dec 6, 2015 | 09:35 AM
Jowens's Avatar
Thank you so much
Old Dec 6, 2015 | 02:56 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
But how would one make those look less plasticardized?
Attached Thumbnails Replacement headlight options-trucklite-headlight-h01-41xs
Johnny*G
May 24, 2016 12:23 PM
SHELL929
Nov 18, 2015 01:51 PM
Slash
Nov 17, 2015 11:54 AM
Cody Anderson
Nov 15, 2015 11:03 PM
Orr89RocZ
Nov 10, 2015 05:21 PM
