Removing console - having a little problem.
Old Jan 1, 2002 | 04:01 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Removing console question
I've got all the screws off of my upper console, got the shifter plate off, the HVAC/strero plate off, kickpanel, etc... BUT. I cannot get the upper console off! The E-brake is in the way! I cannot get the upper console off around it. Any way to remove the e-brake handle, or am I missing something?
Old Jan 1, 2002 | 04:20 PM
Mutiny32's Avatar
oh, BTW, it's a '92 Camaro, so a corner of the upper console where the radio pod is is behind the gauge enclosure.
Old Jan 1, 2002 | 04:30 PM
Blue502's Avatar
There is a screw that you need to remove on the side of the handle near the base. Then it just slides off, button and all.
Old Jan 1, 2002 | 04:33 PM
Mutiny32's Avatar
does it release the brake?
Old Jan 1, 2002 | 05:10 PM
Mutiny32's Avatar
bah! I must be overly gentle on it, because my dad, who has the flu, but is up and about for some reason, got the upper console off, with the lever still on. Thanks anyways!
I'll be taking pictures of the new console's progress as it goes in. The tough part will be that the car's a '92 Camaro, so I'll have to cut the old console apart.
Old Jan 1, 2002 | 05:12 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Pull the ebrake all the way up,then take that one screw out,the plastic handle and button will come off and thats all.It doesnt release the ebrake.With the ebrake pulled all the way up the upper console will come right out,just slide it up the shaft of the ebrake until the upper console clears.
Old Jan 1, 2002 | 05:21 PM
Tonyrodz's Avatar
Transmission: auto
cut?
Why will you have to cut anything off??
Old Jan 1, 2002 | 05:25 PM
Mutiny32's Avatar
because there is no radio/HVAC pod on a '00 T/A Console.
Old Jan 2, 2002 | 08:08 AM
Gta-Paladin's Avatar
Make sure you take the Ebrake outer off, if you've got a leather handle.. because it will most likely rip it apart.
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
