Keys locked in
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Keys locked in
Is easier to look in the rear corner of the window down into the door at
the latch assem.and locate the locking pawl rod.
Peel back the window sweep and rubber.
Slide a wire with a hook on the end and pull up on the locking rod/pawl/arm.
Re: Keys locked in
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
Re: Keys locked in
I never have to worry about it... due to my profession... lol
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: Keys locked in
Locked my keys in my Camaro one night.
Found a ride back to my house, came back, and some bozo had heard about it and taken a flat head screwdriver and hammer and punched my lock without permission!
Now I'm looking for a matching lock set.
Lesson learned, spare key in the wallet now 😒
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Re: Keys locked in
how would some "bozo" find out about you being locked out of your car unless some other massive "bozo" was stupid enough to tell him?
if you are sitting around getting hammered with a bunch of cement heads you shouldn't be getting into your car anyway and if you know
who did it were you man enough to remove that little piece of brain between the right and left hemisphere with the screwdriver (and hammer)?
i know i would be doing that,but i wouldn't have told any drunk morons about how i stupidly locked my keys in the car in the first place.
drunk people are predictably idiotic and annoying as f#$k so you need to rise above the stupidity and use that good old common sense.
