back hatch window shattered 92 camaro rs anniv edition
Old Aug 12, 2018 | 10:26 AM
scarr001's Avatar
Car: 92 camaro rs anniversary edition
Engine: v8 5.0 Tbi
hi,
back hatch window on my beautiful 92 camaro rs anniv edition with t-tops shattered. I can't find the glass anywhere, but did find a 91 firebird hatch with the glass in place, that i am assured will be able to replace my back hatch? anyone have thoughts on this?
Old Aug 12, 2018 | 10:59 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: back hatch window shattered 92 camaro rs anniv edition
Yes, they should be the same. The unibody, doors, hatch and a few other items are interchangeable between firebird and camaro.
Old Aug 12, 2018 | 11:03 AM
scarr001's Avatar
Engine: v8 5.0 Tbi
Thank you Tibo, do you think it will be difficult to swap out? Shouldn't be any rust etc.
Old Aug 12, 2018 | 12:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
They are easy to swap, I believe it is just four bolts at the top and disconnecting the lift struts. I would have a helper for sure as they weigh a lot! I've done it by myself but it becomes very precarious. I had blankets covering the sides of the car and 2x4s to slide it down.
Old Aug 12, 2018 | 12:45 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
That is such good info Tibo! Thank you SO much
Old Aug 25, 2018 | 09:47 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Originally Posted by scarr001
hi,
I don't know where you're located, but I have a 1991 Camaro RS hatch. The firebird spoiler holes in the hatch will be different on the one you mentioned, unless you swap out the metal part
Old Aug 25, 2018 | 10:23 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Thanks for that dagwood, I didn't think it looked right. Mine seems to be wider. I look everyday, I can't seem to find anything.
Old Aug 25, 2018 | 10:29 PM
dagwood's Avatar
Top Answer: 1
You can swap out the metal lid part....put your original one on the firebird glass. The glass and the metal lid parts are exactly the same between a firebird and camaro. The only difference is where they drill the holes to mount the spoiler. Otherwise I have one I'd let ya have for $50 from a 1991 Camaro RS
edit: I see you're in AZ, so my hatch is probably not feasible. I'd buy that firebird hatch and swap out the metal lids. Any hatch from 82-92 camaro or firebird will bolt on, but you'll probably want a 91-92 because of the third brake light
1986 glass is different because that year has the third brake light on the OUTSIDE of the glass, so i believe there are holes in the glass for that
scarr001
South West Region
Aug 12, 2018 09:23 PM
badtenant
May 22, 2013 10:27 AM
LHernandezJr
May 9, 2013 05:37 PM
jamesbob02
Jan 23, 2009 07:22 PM
