can you read rpo codes
Old Jan 9, 2018 | 12:21 AM
1992transam's Avatar
Hi I am new to 3rd gens and i bought a 1992 Firebird was told it was a Gta, The previous owner told me he got the Gta story from a vin decoder website. A friend of mine took a look at the Rpo codes said it was a Trans Am, if you know the Gta and The Trans Am code could you fill me in on on what it actually is! thanks!
Old Jan 9, 2018 | 07:32 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: can you read rpo codes
Y83 = Trans Am
Y84 = GTA
Old Jan 9, 2018 | 08:23 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Originally Posted by 1992transam
hi im new to 3rd gens and i bought a 1992 firebird was told it was a gta going off what vin told the guy i got it from but when a friend of mine that knows more about birds said it was a regular trans am if you can read the rpo i would really appreicate if you could share some info
http://www.google.com/url?sa=t&rct=j...hJNpgG1SAvBHdC
Old Jan 9, 2018 | 04:53 PM
Drew's Avatar
Base model Trans Am. No WS6. F41 suspension. No dual cats. 2.73 gears.
Old Jan 9, 2018 | 06:05 PM
irvan's Avatar
Car: 1989 IROC Z28
Welcome to the forum, a 1992 Trans Am sounds like a lot of fun.
Old Jan 9, 2018 | 06:19 PM
Sweatlock's Avatar
Btw, if you purchase a Pontiac Technical Service Manual for your year it will list all of the codes within it.
Old Jan 9, 2018 | 06:39 PM
would the f41 come with a performance suspension emblem on the dash?
Old Jan 9, 2018 | 06:42 PM
She Can definitely smoke the tires!
Old Jan 9, 2018 | 09:37 PM
Drew's Avatar
Maybe... F41 is considered an upgrade, but it's Level II. WS6/FE2 is Level III, what you'd have in a GTA or Formula.
Considering the emblem was less than $20 at the dealership... Not conclusive.
Old Jan 10, 2018 | 09:23 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Read RPO codes? Yes. Read your first post, well, not very easily! To make it easier for people, please use sentence structure and punctuation. You'll get a lot more help. Some people will just ignore posts that they can't understand.
Old Jan 10, 2018 | 01:43 PM
How could you not understand it! it's simple to read if you have the brains for it! ,Yes It's a little hard to read i posted that when i was tired! But somehow your the only one who felt the need to bring it up, The other people that were nice enough to give me some info didn't feel the need to bring it up!
Old Jan 10, 2018 | 03:43 PM
irvan's Avatar
Car: 1989 IROC Z28
I think Scott was trying to be helpful, sometimes we are a little blunt but i can assure you that he will be there to guide you through a lot of the questions you might have.
Old Jan 10, 2018 | 04:40 PM
tpisierra's Avatar
  • 1G2FW23FXNL220485
    Vehicle:
    FIREBIRD 2 DR
    Year:
    1992
    Build Date:
    1992-05-21
    Found 22,334 vehicles matching that year and model in our database.
    RPO Description Matches
    UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3) 22,334
    UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 22,334
    UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK STEREO AM/FM W/CASS & EQLZR(UX1) 12,701
    U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 22,334
    VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 22,334
    V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 20,779
    WS4 TRANS AM(MERCHANDISING OPTION)(2FS87 + WS4 = 2FW87) TRANS AM(WS4) 1,056
    Y83 TRANS AM PACKAGE(MERCHANDISING OPTION) TRANS AM(Y83) 702
    Y99 HANDLING PACKAGE(USED WITH SE Z7M) HANDLING PKG(Y99) 257
    1SB PACKAGE-OPTION 02 (1SB) 3,280
    1SZ PACKAGE OPTION- (1SZ) 21,331
    19Q MOLDING COLOR,BLACK (19Q) 2,433
    41P WHEEL COLOR,BLACK (41P) 881
    41U EXTERIOR COLOR,PRIMARY,BLACK (41U) 2,471
    6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW) 1,161
    64C TRIM COMBINATION CLOTH, LT BEIGE (64C) 5,980
    64I INTERIOR TRIM,LIGHT BEIGE (64I) 6,057
    649 SEAT BELT COLOR,LIGHT BEIGE (649) 6,057
    7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW) 1,161
    8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 1,899
    9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 1,899
    AAA Unknown 21,257
    AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 8,697
    AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 22,334
    AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 21,980
    AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 20,734
    A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 20,734
    BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 20,734
    B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH TROFEO SPORT COUPE WL3) BODY SI MLDG(B84) 22,096
    C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 15,872
    C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 22,220
    DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 22,062
    D3W GEAR-SPEEDO DRIVEN (25513044) (D3W) 6,153
    D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35) 3,454
    D8N SENSOR VEH SPD (10456088) (D8N) 19,151
    D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81) 3,122
    E5Z ADAPTER - SPEEDO - DELETE 22,334
    E9Z KEY - SPEEDO - DELETE 22,334
    F41 SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR(USED WITH GRAN TOURING PKG Y56) FIRM RIDE & HANDLING SUSP(F41) 257
    GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2) 6,748
    G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 1,782
    IPC TRIM,INTERIOR DESIGN (IPC) 21,980
    J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41) 21,243
    K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 14,670
    K68 GENERATOR,105 AMPERE 105 AMP(K68) 8,465
    LB9 ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9) 750
    MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 19,979
    MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) 19,979
    NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 20,205
    NP5 STEERING WHEEL,LEATHER WRAPPED(USED WITH GRAN TOURING PKG Y56) (NP5) 1,056
    N65 WHEEL AND TIRE,SPACE SAVER SPARE,STEEL STEEL SPACE SAVER SPA(N65) 691
    PW7 WHEEL,16X8,STYLED(ALUMINUM)(SUPERLIGHT) STYLED AL WHL(PW7) 1,446
    QPE TIRE ALL- P215/60R16/N BL R/PE ST TL AL2(USED WITH GRAN TOURING PKG Y56) TIRE(QPE) 257
    T93 LAMP,TAIL AND STOP(SPECIAL)(USED WITH TOURING YP6) SPECIAL TAIL & S/LP(T93) 684
    T96 LAMP,FRONT FOG(USED WITH BERETTA GTZ Z04) FRT FOG LP(T96) 18,323
Old Jan 10, 2018 | 05:25 PM
scottmoyer's Avatar
Seriously? This is how you start out on these forums? I was trying to help you out and providing you some feedback on how best to get the most help from others. But, based on your stupid response, you're on your own. BTW, I do have plenty of brains, and I use it daily, with proper punctuation and sentence structure. Try using yours!
Here's a link to the top 25 Forum Etiquette Tips. Number 10 nails it!
http://www.toptenreviews.com/service...tiquette-tips/
10. In order to be understood by most people, use correct spelling, grammar and avoid slang unless you know the word or phrase will be understood by other members.
Old Jan 10, 2018 | 09:24 PM
OK, You know best!
Old Jan 11, 2018 | 08:05 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Have any pictures of this animal? And welcome aboard!
Old Jan 12, 2018 | 09:42 AM
Old Jan 12, 2018 | 07:42 PM
tpisierra's Avatar
Nice squarebody.
Old Jan 13, 2018 | 11:13 AM
tarheel
Apr 8, 2008 08:40 PM
Sostar18
Aug 4, 2002 08:48 AM
richardc
Jul 24, 2002 12:10 AM
nos
Jan 24, 2002 12:13 AM
Like a ROC 89
May 31, 2001 05:11 PM
