Rotting issue on convertible top of windshield
Old May 2, 2018 | 10:34 PM
Thirdvert89's Avatar
What can I do to repair this
Old May 3, 2018 | 12:46 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Rotting issue on convertible top of windshield
Its rust. Time to cut it out.
Old May 3, 2018 | 08:04 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
remove the trim and weather strip, get a knotted wire wheel or grinder and go to town. Stop when you hit good metal and replace.
Old May 5, 2018 | 04:16 PM
So if I cut out All the rust and take out weatherstrip new strip stick in and seal easy I appreciate your help
Old May 15, 2018 | 02:39 AM
If I scrap out all the rust no metal left in there what do I put
Old May 15, 2018 | 05:13 AM
midias's Avatar
You will have to weld in more metal or maybe fiberglass
Old May 15, 2018 | 06:08 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Jesus Christ. That’s awful. What’s really left good on the car, and where else is there rust?
Quantify the project before you get too deep.
Is this the car you just bought? Sorry to see this. Ugh.
Old May 15, 2018 | 11:29 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Wow that is bad. You may have to find a donor car and cut the upper part of the windshield post and weld it back in. That will require some serious work but it may be your only choice.
Old May 16, 2018 | 12:58 AM
Yes it's a car mr Lou battaglia sold me suspension is all rotted and floors . Battery area is completely rotted out lots of surface rust in engine bay
Old May 16, 2018 | 01:24 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
I would recomend to find another chassis. From what you described for rust of what you can see I imagine its much worst where you cant. Walk away from this chassis and find a donor or part this out and buy another car.
Old May 17, 2018 | 12:38 AM
I found a 92 firebird convertible a local junk yard. If I cut the upper frame of windshield will it work on an 87 trans am
Desertvert87
Apr 9, 2018 03:47 PM
Kevman
Feb 4, 2007 07:36 PM
Meatwad
May 22, 2005 03:59 PM
RS'er
Jul 11, 2002 09:06 PM
92 Rag
Nov 5, 2000 07:03 PM
