power trunk pull down
Old May 18, 2018 | 07:05 AM
The Big Hat's Avatar
Car: 89 RS
Engine: 5.7 T.B.I.
Does anyone know if a firebird power trunk pull down will work on a camaro? My mechanism has been ruined by some thieving jerk. I can't find one locally but I have found a firebird parts car with one in it. I just don't want to go through the trouble of pulling the part and paying for it to find out it won't fit right.
Old May 18, 2018 | 07:13 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: power trunk pull down
I believe they are the same, year for year, but if the year of the other car is a different year, then the pulldown can be a different design.
Old May 18, 2018 | 07:17 AM
Car: 89 RS
Engine: 5.7 T.B.I.
My car is an 89 and I'd put this donor at about 90-91'. It's hard to tell it's missing a lot of pieces. The module is a different design though. Mine has two rails that are visible this one looks more condensed than mine does. It is hard to tell if the bolt pattern is similar because the design is so different. I just looked on ebay and there is no way i'm paying 250 dollars for this thing. That's ridiculous. Mines rails are all loose and it won't stop running the motor if I plug it in but I will take it off and try fixing it before i spend that kind of money on one.
Old May 18, 2018 | 08:51 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
The same pull down assembly (depending on year) was used in Cadillacs, Olds, Buick
cars.
Here is a list for the 86-91 pull down motor assembly (thanks to Lon at top down solutions))
and which car/year usage FYI that I asked about above:
Buick: 1980-93 Electra, 1985-93 Park Avenue, 1980-93 Riviera, 1992-96 Roadmaster
Cadillac: 1987-93 Allante, 1980-96 Brougham, 1980-93 Eldorado, 1980-96 Fleetwood Sedan,
1985-93 Fleetwood, 1980-83 Fleetwood, 1980-93 Seville
Chevrolet (Chevy): 1986-91 Camaro
Chrysler: 1989-91 TC by Maserati
Oldsmobile: 1988-93 98 Regency, 1986-89 Toronado
Pontiac: 1986-91 Firebird, 1985-92 Grand Am
So if your parts yard hunting for a hatch/trunk motor assem. you know which cars to look for.
Old May 18, 2018 | 09:02 AM
Car: 89 RS
Engine: 5.7 T.B.I.
oh wow! thank you! That widens the prospects a bit!
Old May 18, 2018 | 09:07 AM
Car: 89 RS
Engine: 5.7 T.B.I.
Now some mechs look different than mine will they do the same thing and line up ok then?
Old May 18, 2018 | 02:37 PM
Drew's Avatar
No. 86-91.5 won't swap with 91.5-92.
Old May 18, 2018 | 02:43 PM
Car: 89 RS
Engine: 5.7 T.B.I.
ok, thanks. I'll have to start scouring the bone yards. I just started driving this car again after 5 years and now I can't go three blocks without someone offering to buy it off of me! It is as buggy as any car that sat for 5 years but i'm torn about selling it.
Old May 18, 2018 | 02:52 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Keep it. You can drill some holes in the mechanism and run a couple of bolts through to make it a fixed latch. Just make sure it is adjusted right and it will work like any trunk lid. Problem solved.
Old May 18, 2018 | 02:55 PM
Car: 89 RS
Engine: 5.7 T.B.I.
i posted it for sale if you want to see it look in my posts. i don't know how to remove a post though.
Old May 18, 2018 | 04:21 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I’m running one from a Cadillac on my ‘88. Sure beat paying over $200 for a rebuilt one. Total cost of repairing mine was a little over $30..and that included replacing the nylon guides in the frame, (which is what killed it in the first place)...mine had turned into thousands of pieces of nylon dust.
Old May 18, 2018 | 06:13 PM
Car: 89 RS
Engine: 5.7 T.B.I.
That's what mine needs I'm pretty sure, it doesn't even have them, where did you get your nylon guides through? Mine is just loose in its tracks.
Old May 18, 2018 | 10:26 PM
Drew's Avatar
You can get all the parts you will ever need for the pulldown assemblies from Lon @ http://www.top-downsolutions.com/
The clear plastic motor housing, and gear nut are available in the aftermarket from places like Rock Auto. Pretty sure there's at least a couple other sources for the slides. It's really not that difficult to rebuild one, just takes a bit of time. Working with all the dirty greasy parts is about the worst of it.
Old May 21, 2018 | 09:39 AM
Car: 89 RS
Engine: 5.7 T.B.I.
Everything on my car is old and greasy! In fact, the driver is older than the car and getting that way too so I better not discriminate too much! LOL!
Old May 21, 2018 | 09:41 AM
Car: 89 RS
Engine: 5.7 T.B.I.
picked up an 88 iroc for my kid to learn on the other day, wouldn't you know the whole mech is missing! oh boy! For 500 bucks though! We'll have a good time finding all the pieces he's going to need!
1992 Trans Am
Jun 1, 2017 10:10 PM
iansane
Nov 30, 2010 01:13 AM
fastfirebird
Aug 20, 2006 01:30 PM
Knight350
Sep 5, 2005 11:07 PM
