Door window removal
Old Aug 4, 2018 | 03:21 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Door window removal
Ok, I’ve tried like crazy and gave up on the “cheat way” and decided to go the correct way and remove the rivets.
Does anybody know the procedure? I see people mention to punch the center out (i tried, it wont move) then drill the rivet.
am i the only one svared to do thiss seeing that the window is....glass??
Also dpes anybody know what drill bit size to use? Nobody mentions the drill bit size!!
Thanks guys!!
Old Aug 4, 2018 | 04:03 PM
Drew's Avatar
Re: Door window removal
Get yourself a nice long and heavy punch. If at all possible, hook your fingers around the bottom of the window/track to keep it steady, line up the punch with the post in the center of the rivet and give it a swift whack with your hammer. The post should pop out fairly easily. Then use the smallest drill bit that is enough larger than the inner hole of the rivet to cut away the head leaving only the tube, drill until it just barely cuts through the head, and if necessary use a tool to pry the rim of the rivet away. Then you can push the rivet tube out of the hole with your punch.
The other way to go is to unbolt pretty much everything in the door, and wiggle/walk the lower window track roller out of it's guide. Detach the weatherstripping at the rear of the door. Then wiggle and walk the window until the roller is back by the gap created by removing the weatherstripping, and carefully work it up, tilting the window until the washers that retain the window to the lower track slip up and out of the door, then tilt the window towards the car rolling it over until the roller clears. It's like moving an oversized couch through a tight doorway, gotta get the angle just right. If you're not concerned about the door you can also flex the inner structure or the outer skin far enough apart to make a bigger gap, but I wouldn't recommend that if you want to save the door.
Old Aug 4, 2018 | 07:51 PM
1989karr's Avatar
Engine: 3.4 / 5.0
thanks Drew! I’ll have to try. Im scared about shattering the window but i’ll give it the ol one two and see what happens!
Old Aug 5, 2018 | 08:21 AM
Drew's Avatar
Look at the bright side, if the window shatters, it'll be easier to remove.
Old Aug 6, 2018 | 07:52 PM
1989karr's Avatar
Engine: 3.4 / 5.0
You have a point there lol
Old Aug 9, 2018 | 02:57 PM
1989karr's Avatar
Engine: 3.4 / 5.0
I swear the rivets GM used in mine are made out of titanium. I tried a punch and it didn;t move the center of the rivet at all. It could have been I was scared to shatter the glass but still, I think I punched it pretty hard.
I ended up using a dremel cutting when and grinding off the rivet head then tapping the center out slowly..slowly because these things are damn hard lol
I then proceeded to grab the rest of the rivet and throw it far across the street as hard as I could. 1 down...2 more...harder to reach rivets of course.......to go.
Why did GM use rivets for these? I noticed in 1st, 2nd, and 4th gen videos that the glass is all bolted in!
Old Aug 9, 2018 | 03:31 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
1989karr throwing rivets like...
Old Aug 9, 2018 | 04:03 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Damn right!!!! lol
Old Aug 9, 2018 | 05:10 PM
Drew's Avatar
because rivets held the window in for 20 years?
Old Aug 9, 2018 | 05:29 PM
1989karr's Avatar
Engine: 3.4 / 5.0
lol but bolts did fine on my S-10 and Pontiac 6000 for the same 20!
I admit that bolts did NOT do well on my 1990 Camry though.....
Old Aug 10, 2018 | 12:30 PM
1989karr's Avatar
Engine: 3.4 / 5.0
I got the monster out!!!
Old Aug 10, 2018 | 12:31 PM
Drew's Avatar
Great success!
Old Aug 10, 2018 | 03:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Great success!
now for the passenger side AND i want to try get a set that i hope is still at the junkyard! I like throwing rivets lol
Old Nov 12, 2021 | 10:41 AM
KCG's Avatar
KCG
Car: 89 IROC
Couple year old thread but it came up first when searching for Window Removal.
My question is, after drilling out the rivets are you just using bolts to put it back together?
Old Nov 12, 2021 | 11:49 AM
1989karr's Avatar
Engine: 3.4 / 5.0
I prolly won;t be putting it back for a long time.. but yes! that is my plan. Stainless steel fasteners / bolts and lock washers!
Old Nov 12, 2021 | 02:12 PM
KCG's Avatar
KCG
Car: 89 IROC
Ha ok. I took some pictures of the pins, rivets etc when I pulled mine apart. Do you mind if I add them to your post?
Old Nov 12, 2021 | 02:35 PM
1989karr's Avatar
Engine: 3.4 / 5.0
No problem at all!
I here people prefer to use rivets to replace the old ones.....I have no idea where you would find replacement rivets for the window though? I think they are a softer rivet and its kinda scary rivetign through glass.
Old Nov 12, 2021 | 03:13 PM
KCG's Avatar
KCG
Car: 89 IROC
Thought I would add a couple pictures for anyone not knowing exactly what they were looking for when doing this for the first time.
Here's what the pieces look like after being removed.
The pin that goes thru the rivet sleeve, the sleeve, and the head of the rivet after being drilled.
The pin comes out of the door skin side after you punch it out.
Like Drew recommended above, I used a good sized heavy punch to start the pin moving, then used the smaller one to drive the pin out the rest of the way thru the sleeve.
Next is the glass looking from the skin side of the door. This is what it looks like in there with the pin coming out.
And the drill bit I used to remove the head off the rivet
A 1/4" would probably work fine but mine was MIA so I used the next bigger size. 9/32
This is the first door I ever removed a panel from and the plastic had never been touched. So without removing it, I put a slice in where my light is hanging because I was removing the door handle & lock too. If you can zoom in where the yellow tape is, you'll see the 3 rivet locations where I pushed the punch & drill bit thru the plastic cover. Actually only 2...the one at the front of the door was accessed thru an opening in the sheet metal. With the window down about an inch or so, you can get all 3 in sight without moving the glass again.
Obviously this is the passenger side door. Worked the same on the drivers door.
Old Nov 12, 2021 | 05:20 PM
1989karr's Avatar
Engine: 3.4 / 5.0
How did you not break the glass?
I was worried about breaking the glass with a punch.... honestly the way i did.... cutting / dremeling it was a real pita hahaha
ALSO CRAFTSMAN drill bits suck from my experience lol if I just got a good drill bit I probably would have saved myself some major headache.
Old Nov 12, 2021 | 07:05 PM
KCG's Avatar
KCG
Car: 89 IROC
Honestly didn't even worry about it. There's so much movement in the glass & mechanism holding it, I just hit it!
I did have the outside sweep off too which may have give more play, but that probably worked against me anyway.
Old Nov 15, 2021 | 11:44 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Nice!!
I don't understand why GM couldn't be normal and just use bolts to hold the glass like every other manufacturer...........even my s-10 uses bolts!!!!!!!!
Old Nov 15, 2021 | 11:48 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Rivets are quicker and cheaper. I fought this all the time as a service engineer.
Old Nov 16, 2021 | 11:19 AM
1989karr's Avatar
Engine: 3.4 / 5.0
yeah, i wish they went chap on the other cars and not the F-body though!! lol
ob1kadrobe
Oct 16, 2014 01:53 AM
Bruce91RS
May 28, 2013 05:58 PM
NufNuffZ28
Exterior Parts Wanted
Jan 31, 2011 03:16 AM
rs90 driver
Apr 4, 2009 07:17 AM
adam86
Jan 1, 2007 09:37 PM
