Front cover - am I missing something?
Old Oct 2, 2018 | 05:52 AM
KCG's Avatar
KCG
Car: 89 IROC
There are 6 evenly spaced tabs riveted to the bottom of my front bumper. The second picture shows them best, all right on the front edge. Does anyone know what these are for?
Old Oct 2, 2018 | 09:48 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Front cover - am I missing something?
They're holding on your chin spoiler/front ground fx.
Old Oct 2, 2018 | 10:57 AM
KCG's Avatar
KCG
Car: 89 IROC
These are on the bottom of the ground fx. Are you saying there should be something under this?
Old Oct 2, 2018 | 11:28 AM
Drew's Avatar
Old Oct 2, 2018 | 11:38 AM
Car: 1983 Z28
Does each tab have a bolt in it or is that just a trick of the picture?
Drew posted that exploded diagram, it probably answered your question.
Old Oct 2, 2018 | 11:56 AM
KCG's Avatar
KCG
Car: 89 IROC
No bolts in those tabs. They're riveted to the bottom of the ground fx and the other end is open. I found this and thought it was the answer with the 6 holes in it, but its not what Drew posted.
http://www.hawksmotorsports.com/fron...-reproduction/
#16 makes more sense. Thanks Drew.
Old Oct 2, 2018 | 06:19 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I'll have to crawl under my car to be sure, but isn't there a curved plastic panel that essentially seals the bottom of the spoiler, and ends at the lower radiator support that attaches to those tabs?
Old Oct 2, 2018 | 06:50 PM
Drew's Avatar
You mean #16? LOL
Old Oct 2, 2018 | 07:21 PM
KCG's Avatar
KCG
Car: 89 IROC
oh, I was looking at #16 as being "hollow". That big square area is a solid piece of plastic or is it a big hole?
Regardless, should we be able to see where the top side mounts in the pictures I posted above?
Old Oct 3, 2018 | 12:59 AM
the_assman's Avatar
Car: 90 vert
your first pic shows it better but the top mounts up behind the bumper brace , #31. you see a loose piece of plastic with bolt hole spots in your pick right behind the support , the 2 pieces of plastic fit together and bolt up behind the support.
Old Oct 3, 2018 | 01:50 AM
Drew's Avatar
#15 and 16 overlap, and the four bolts thread into the rear flange of the impact bar. #16 is a curved piece of solid plastic that helps direct cooling air up and into the radiator.
Old Oct 3, 2018 | 06:03 AM
KCG's Avatar
KCG
Car: 89 IROC
Awesome, thanks!\
now I just have to find one
Old Oct 3, 2018 | 09:36 PM
the_assman's Avatar
Car: 90 vert
where in md are you ?
i think i have a spare
Old Oct 4, 2018 | 05:16 AM
KCG's Avatar
KCG
Car: 89 IROC
I'm about 10min off I95 in the northeastern corner. A few miles south of Pa and about 20 from Del.
Old Oct 4, 2018 | 06:18 PM
the_assman's Avatar
Car: 90 vert
i'm right on the va side of the woodrow wilson bridge , how far of a drive is that for you
if it's a close enough drive your welcome to the panel. i have handful of other parts i'll be tossing out. let me know if there's anything else your looking for , i may have it and make the drive more worthwhile
Old Oct 8, 2018 | 06:40 AM
KCG's Avatar
KCG
Car: 89 IROC
Thanks, I'm in Albuquerque right now and driving back across the country next weekend.
ill pm you.
Old Dec 27, 2018 | 05:02 AM
KCG's Avatar
KCG
Car: 89 IROC
PM'd you
DanielRicany
Feb 19, 2018 07:33 AM
Webnerdnick
Feb 18, 2018 08:59 PM
Malicious3rdgen
Oct 28, 2013 01:43 AM
mike89z
Sep 5, 2002 10:53 AM
smokin87iroc
Aug 7, 2001 09:06 PM
