Door Question...
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Door Question...
Are all thirdgen doors the same from '82 to '92?
Are the Camaro doors the same as Firebird?...
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Door Question...
All 82-92 doors will bolt to any 82-92 F-body.
'Early' (82) doors and 'late' (92) doors are not built the same and have different internals parts. Most internals parts are interchangeable,....... not all.
Transmission: Pro-built 700R4
Are the holes for the ground effects the same between Camaros and Firebirds? I need to replace the driver door on my '91 GTA and I came across a '91 Z28 that is being parted out. The door looks to be in really good shape, but I'm not sure that the GFX will transfer over without drilling new holes (which I'd rather not do.
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
I believe the ground effects are different, but the holes could be the same....On my 91 TA they're below the door on the rocker panel.....not on the door.
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
I don't think you're understanding the part I'm asking about. I'm talking about the piece that mounts to the door (obviously Camaro body parts look different). If you have a correct '91 T/A, then you should have something on the door as well that is a part of the "aero" appearance package. I was asking if the mounting holes for those lined up the same as the appearance package on the Camaro.
Are you talking about the ground affects ON the bottom of the door? My Z28 does not have that and I don't see any holes to mount it to.
Yes, the pieces that mount to the door itself. I know the doors are the same between Firebirds and Camaros, but I was curious if the holes are the same between the two models.
CARHARTTKOWBOY
Interior Parts Wanted
Sep 21, 2012 09:36 AM
conlinj
May 15, 2006 03:44 PM
