15" to 16"
Old Jan 14, 2002 | 11:17 AM
brihoop's Avatar
15" to 16"
i have 15x7 rims on my car and i would like to go to 16x??. i was wondering if that would mess up anything about my car and what size would fit right? my tire size is P215/65R15, what tire size would i go to? just let me know about EVERYTHING that i would have to do to chang e from 15" to 16"
Old Jan 14, 2002 | 12:50 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
245/60R16's should be the same diameter tire as your running now...
John
Old Jan 14, 2002 | 12:58 PM
brihoop's Avatar
well i have a set of 245/50R16 tires and they are too wide for the car. they rub on the wheel well. are the ones you told me thinner than those?
Old Jan 14, 2002 | 01:59 PM
okfoz's Avatar
thats interesting, because thats the size that came on my formula. Make sure the rims are not the wrong offset. my front wheels rub ever so slightly on my plastic inner fender when backing up and cranking the wheel all the way to one side...
John
Old Jan 14, 2002 | 02:11 PM
brihoop's Avatar
how do you check the offset?
Old Jan 14, 2002 | 02:18 PM
okfoz's Avatar
take the wheel off, then from the back side place a piece of wood or something straight across the wheel, then measure the depth.
John
Old Jan 14, 2002 | 02:24 PM
brihoop's Avatar
what should it be?
Old Jan 14, 2002 | 03:14 PM
okfoz's Avatar
I wish I knew, I would post it. Someone around here should know though...
John
Old Jan 14, 2002 | 03:29 PM
brihoop's Avatar
how do you figure out the back spacing?
Old Jan 14, 2002 | 03:49 PM
brihoop's Avatar
i was told that p225/50R16 is recommended for switching from p215/65r15. is that true?
Old Jan 14, 2002 | 10:39 PM
ONEFINE8T9's Avatar
i would say your best bet is to go with the standard WS.6/IROC wheel which is a 16x8. The correct tire size for these wheels is a 245/50/16. Some like the 255/50/16s on back becouse they are a little bit wider but what they dont realize is the wider the tire the larger the profile and it looks stupid IMO. BTW dont worry about offset if you get these wheels they are simply labeled front/rear
Old Jan 14, 2002 | 11:50 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Same thing goes for the front. I put 225/55/16 on my GTA. They look stupid Now i have to take um back off. Oh well I got a new set of firehawks on my parts car a couple weeks ago. I'll be put'n them on in the spring.
Oh yea. the GTA 16 wheels have 1/2 in. less offset in the front.
Old Jan 15, 2002 | 03:21 AM
Jza's Avatar
Jza
John
That's measuring backspacing. To get offset, you take the width of the wheel, divide by two and subtract the backspacing from that answer. Your offset for any normal wheel should come close to 12mm on a thirdgen f-body.
You say your tires rubbed? Was it a severe rub (steering interference), or was it just a light rub on sharp turns? That size should have fit your car, but thirdgen 16" wheels are front/back specific. They also usually came with thin spacers (but not always the case).
