Custom tail panel concept
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Stock bumper
No bumper with defuser 1
No bumper with defuser 2
A couple of concept drawings for a shaved rear bumper with defuser. This will be done in fiberglass in two pieces.
Re: Custom tail panel concept
I’ve already started. A 1” X 2” X .120” tube was added to the middle of the rear bumper and 13 pie cuts were made the entire length and welded to match the curve of the back of the car.
I will make a foam mold and fiberglass a cap and defuser.
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I was confused after reading your post title then seeing your drawings. I was thinking you were changing the tail light panel as opposed to the rear bumper design but either way it is an interesting idea. I always liked the way this member changed his rear bumper
REAR BUMPER SHAVE - Third Generation F-Body Message Boards
Beginnings for the fiberglass mold
Not the final shape yet
I’ve begun the mock-up process for the fiberglass mold. It will be a male buck so that multiple pieces can be made in case I need a replacement.
New rear bumper in fiberglass. Defuser in the process of being made.
Car: 1989 Trans Am GTA
Transmission: M28 T56
At first, since it said "Tail Panel" I somehow got stuck in a loop looking at the tail lights and thinking "those are stock?!?! Whats different?"
Then I noticed the bumper. lol.
I lik eit. I've always liked Center Exits though.
Final update to this thread. Rear bumper is installed and awaiting for the taillights and the diffuser.
After installing the taillights, I think it really extenuates the modifications to the rear bumper. It gives more of a prospective of the flush look that I had in mind when I started this project.
Concept Drawing
Final product
Finished diffuser installed. This completes the back of the car just as I had imagined it.
Transmission: World Class T-5
Axle/Gears: BW 3.45
Awesome! Thanks for posting the link on ThirdGen Expo.
jerflash
Exterior Parts for Sale
Feb 2, 2008 07:14 PM
