Amount of paint?
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Amount of paint?
How much paint would I need to paint the body, door jambs, and engine bay? I'm looking at a gallon of paint with a quart of reducer, so 1.25 gallons in total. Could I get by with it?
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: Amount of paint?
For primer, I planned to use epoxy primer. With the plastic bumpers, would I need adhesion promoter, or would the epoxy primer bond well to the plastic?
Engine: 5.7
Axle/Gears: Stock
Using the Eastwood paint ,no, it was built in. Check with the manufacture of the paint you are using.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I've done a whole car in BC/CC with under 1/2 gallon (T-Tops)
I would still put a layer of acrylic primer over the epoxy primer. I've had some adhesion issues before between the epoxy and a single stage.
You'll also want to block sand the filler primer.
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Car: 91 Rs
Engine: 327 SBC
no, always use adhesion promoter on bare plastic. ALWAYS. I am a painter and can assure you that there is no DIY product on the market that is designed to be applied without an adhesion promoter on raw plastic.
Car: 1985 Z28
Engine: 305 LG4
The urethane bumpers on these cars are actually pretty porous, so epoxy and urethane primers stick fine with no adhesion problems. You dont need to sand to bare urethane either, unless the old paint is cracked. But you can spend the money on an adhesion promoter if it makes you feel better.
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I am also a professional painter. If you and to the bare urethane, you NEED an adhesion promoter. If you are just sanding the current paint that's on it, but not getting down to any bare urethane, then you will be just fine without it.
There's nothing harder to feather out than peeling paint. I'd absolutely never spray bare urethane without using adhesion promoter. You can get it in a spray can for like $15. That's the absolute cheapest insurance policy in the world to not have the nightmare of peeling paint on your bumpers.
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I ended up getting the adhesion promoter anyways. I figured I'd rather just put it down then to not put it down and regret it later. Plus it's cheap enough to not worry about it
