possible to take apart the headlight actuator arm?
Old Mar 24, 2021 | 04:19 PM
fuchs's Avatar
Car: T/A
Engine: v8
I've taken apart the 1988 Firebird headlights for a good cleanup, re-grease, and replacement of the bushings. To ease the stress on the gears, I'm trying to get everything to turn as smooth as possible. One thing I can't seem to get any smoother is the two cups/***** on the actuator arm. They move, but far from smooth. I guess there is dirt or old grease or whatever in there. I've tried to stuff some grease in, but it's just too tight in there. None of my efforts make the ***** move in the cups any smoother.
Is it possible to take the cups apart? Is there some smart way to get it greased or cleaned?
I've tried pulling the ***** out, but the actuator arm starts to bend long before that would happen.
Old Mar 28, 2021 | 09:35 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: possible to take apart the headlight actuator arm?
I got them out, though I don't remember how exactly. I might have put them back in the assembly and used screw driver for leverage
Old Mar 30, 2021 | 03:56 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
its like a socket. Pops out.....id be wary of breaking it though.
Old Mar 30, 2021 | 05:29 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Scooter is right. If that part were still mounted in the car then you could easily use a small pry bar or screwdriver between the two pieces and separate them.
Old Mar 31, 2021 | 02:19 AM
fuchs's Avatar
Car: T/A
Engine: v8
Thanks ! I'll re-assemble it and try the screwdriver approach.
86White_T/A305
Jul 12, 2020 11:20 PM
88GTAvert
Aug 18, 2009 08:48 AM
Snowblind
Aug 23, 2006 06:03 PM
CC89Formula
Jun 29, 2006 11:41 PM
Gambit69
Sep 11, 2003 09:09 PM
