how does this happen?
Old Jan 10, 2022 | 08:47 AM
ohioscott's Avatar
Car only has 65000 miles wtf. How are we fixing this?
Old Jan 10, 2022 | 09:31 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: how does this happen?
Does not look too bad. Some water got trapped and salt most likely cut it out and weld in new steel
Old Jan 10, 2022 | 11:39 AM
ohioscott's Avatar
any patch panel available?
Old Jan 10, 2022 | 12:14 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Ohio happened, in SW Ohio myself. Your best bet is either finding a rust free-ish body to rob from or fabricating patch panels.
1987 Chevrolet Camaro Coupe 2D $400
Old Jan 17, 2022 | 11:56 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Cowl drain and/or fender drain hole most likely clogged. All that rust is right where the fender is supposed to drain. Flushed mine out a couple weeks ago, was full of ancient leaves and even a 90s era McDonalds straw.
Old Jan 17, 2022 | 05:37 PM
ohioscott's Avatar
Grinding next
Old Jan 17, 2022 | 06:21 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
That’s a common spot for rust on these cars. Typical for cars exposed to winter road salt. It’s not too bad to repair and it looks like you are on the right track with what you have done so far. Problem is, that won’t be the only rust on the car. You need to check the other common spots such as, rear inner wheelhouses, front shock towers, passenger side firewall/toeboard, rear bumper mount and floor pans. It may not be obvious behind the seam sealer and undercoating. Use a sharp awl and poke those areas.
My restoration thread may be useful to you.
https://www.thirdgen.org/forums/memb...ns-am-gta.html
Old Jan 21, 2022 | 08:44 PM
ohioscott's Avatar
not a great welder but it'll due
Old Jan 21, 2022 | 08:53 PM
Car: '89 GTA
Engine: ZZ6TPI
A bit more heat in the welds will help. Grind them down, epoxy primer and seam sealer and it will be fine.
Old Jan 21, 2022 | 10:57 PM
silverstang84's Avatar
Car: 88 IROC
Repair job looks good so far
Old Jan 22, 2022 | 11:19 AM
ohioscott's Avatar
I need more practice adding heat has a tendency to burn holes.
Old Jan 22, 2022 | 03:18 PM
Car: '89 GTA
Engine: ZZ6TPI
Are you using 0.030” wire? If so, try going down to 0.023” wire. It will burn through less.
Old Jan 26, 2022 | 05:25 PM
ohioscott's Avatar
pass. side alittle better
Old May 11, 2022 | 01:16 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Old Jun 6, 2022 | 09:46 AM
kfsullivan's Avatar
Car: 1988 Trans Am w/ WS6
Transmission: 5-Speed
Ignore. Wrong post.
Old Nov 14, 2022 | 02:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
wrong thread,why do these threads run into each other
Old Nov 14, 2022 | 05:25 PM
NoEmissions84TA's Avatar
This is what you want to do.
Old Nov 19, 2022 | 04:57 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
this was my patch job on that area for both sides, leaves and road muck get caught here between the fender and this section and rot it out along with the cowl drain.
i didn’t go crazy with trying to make it look factory since it’s behind the fender anyways
Old Nov 19, 2022 | 07:52 PM
LosingNirvana's Avatar
Car: 1983 Z28
Engine: Carb LG4 :(
Transmission: NWC T5
Axle/Gears: 9 bolt 3.27 posi
I've been doing the same thing to mine. Driver side is really rough, I did the passenger side already. Since I have to do floors I just cut it all out and rebuilt it piece by piece. I put the pictures in a spoiler because for whatever reason it makes them really big when they come from my phone.
Spoiler
Old Dec 4, 2022 | 06:30 AM
mikelstudy_1's Avatar
__________________
Linson
Dec 1, 2020 09:28 PM
gt4373
Apr 9, 2018 10:06 PM
gt4373
May 4, 2016 11:04 PM
gt4373
May 3, 2016 11:06 PM
gt4373
May 3, 2016 11:05 PM
