front facia rust
Old Dec 29, 2024 | 06:04 AM
TX50's Avatar
front facia rust
hi friends! I'm a brand new owner of a TA1982 from France (sorry for my bad English!) in order to build a K2000 replica. As I started to remove the front facia rusted, see picture below, I was wondering if this part was available in spare part?
front left
front left
Thanks for you reply
Old Dec 29, 2024 | 08:05 AM
Roorancher's Avatar
Car: 91 TA Vert WS6-94 TA Vert
Engine: 5.0/5.7 LT1
Axle/Gears: 2.73-3.42
Re: front facia rust
That's known as the Radiator Supporr..
Send your picture and explanation to Brett via message. He has lots of parts, and hes legitimate. Ive purchased from him before.
Bon chance!!!
Old Dec 30, 2024 | 06:15 AM
TX50's Avatar
Seems there are many "brett" in this forum. Do you have his username please?
Old Dec 30, 2024 | 07:06 AM
Roorancher's Avatar
Engine: 5.0/5.7 LT1
Old Dec 30, 2024 | 07:15 AM
Roorancher's Avatar
Engine: 5.0/5.7 LT1
Old Dec 30, 2024 | 08:01 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
@firebirddude142 That is his member name here at ThirdGen.org
Below is his thread where you can inquire about parts.
What do you need? I’ve parted over 40 cars...
Old Dec 30, 2024 | 12:42 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
This part is most commonly called the core support or radiator support. Used is going to be the only option for that. Will need to drill out all of the spot welds and plug weld in the replacement panel.
That's quite a bit of rust there and it's not a real common spot to rust through. Might be a specific reason for it, but how is the rest of the car (rockers, floors, wheelhouses, firewall, cowl, etc.)? Best to evaluate the whole thing before tearing into this rust repair.
Old Dec 31, 2024 | 09:26 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
^^^^THIS.
Seems very odd to me that there's so much rust on that one part of the car while there is no apparent rust anywhere else in that pic.
Old Dec 31, 2024 | 05:10 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by ironwill
^^^^THIS.
The battery sits right behind that, perhaps it suffered a bad battery leak at some time and the acid contributed to the rust/rot?
Old Dec 31, 2024 | 05:47 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
The battery is on the passenger side in 82-84 firebirds. Unless this car had a rt hand drive conversion and the moved the battery to the left Side.
Old Dec 31, 2024 | 06:57 PM
OrangeBird's Avatar
Car: 1989 Firebird
Fair enough, thanks for the info (only ever owned late model birds)......
Maybe the rot monster was especially hungry the day he visited the OP's car
Old Jan 3, 2025 | 05:56 AM
TX50's Avatar
Found a solution from my own. I'll make some metallic angles to be welded. this will cost few euros and not so hard to make it!
An another question is how to adjust the right side mirror as it seems to be electrical (didn't find any control pad)?
Old Mar 10, 2025 | 01:50 PM
TX50's Avatar
Hi everybody! Any answers for the right side mirror control? I have a new request: i'm looking for the gasoline pipes from the tank to the engine. Didn't find on ROCKAUTO and other websites... Also, is there any procedure to change the motor mounts as bolts are in the front arm, behind the suspension spring and so hard to reach them???
Thanks for your help !
Old Mar 10, 2025 | 02:46 PM
Car: '89 GTA
Engine: ZZ6TPI
Inline Tube will have the fuel lines.
https://www.inlinetube.com/
Motor mounts are really hard to do with the front control arms in place. I did mine while I had the control arms out anyway to replace the bushings. Given the age of the car, you may want to consider that. You can buy a whole new control arm with new bushings and ball joint on RockAuto.
Also, suggest starting a new thread for new topics.
Old Mar 11, 2025 | 06:24 AM
TX50's Avatar
Thanks for reply Transam. one last question: if i put bolts inside the arm and nut outside, should it be acceptable (reverse to the original mouting)?
Old Mar 11, 2025 | 06:39 AM
Car: '89 GTA
Engine: ZZ6TPI
Never tried that. If they fit that way, then I don’t see an issue.
Old Mar 11, 2025 | 06:41 AM
TX50's Avatar
OK, will try this way. Any answer regarding the right side mirror?
Old Mar 11, 2025 | 07:05 AM
Car: 82 TA
The does your car have power mirrors? Is there a control pad on the center console? If not, the driver side usually has a little control **** on the drivers door and the passenger side you move the mirror itself.
Todd Hosselkus
Jan 4, 2025 12:51 PM
Necron
Nov 25, 2019 08:46 AM
KNIGHTE
Jun 2, 2015 09:20 AM
liveyourself
Aug 28, 2008 04:34 PM
C4 Suke
Jun 16, 2004 10:39 PM
