Opinions needed to body concept
Old Jul 15, 2025 | 09:30 PM
armyvman's Avatar
Car: 1989 Camaro IrocZ
Engine: 350 5.7L V8
Transmission: 4 speed automatic (stock)
I’ve started working on the body of the iroc im restoring and I’m playing with AI to come with different concepts.
What are your opinions on this one? Too much?
Old Jul 16, 2025 | 12:11 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Re: Opinions needed to body concept
The wing looks a little out of place, in my opinion.
Old Jul 16, 2025 | 12:28 AM
armyvman's Avatar
Engine: 350 5.7L V8
I should have mentioned in this scenario the wing would be the 90’s model stock high wing, which I realize that’s not what it looks like in the pic. AI can only do so much with prompts. I don’t know if that changes your opinion or not.
Old Jul 16, 2025 | 08:13 AM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
not bad.. are you also going to put on the 91-92 ground effects as well?
Old Jul 16, 2025 | 09:17 AM
armyvman's Avatar
Engine: 350 5.7L V8
we were talking about it, if we could find a set in decent shape.
Old Jul 16, 2025 | 01:50 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
I'm really a fan of the factory look. We're only running a 2" cowl hood on the Firebird (VFN, IIRC) because we need to clear the carburetor and the single-plane intake. Otherwise it would be a flat or the 'power-bulge' hood.
The Integra Type-R-like rear wing is THE thing I'd change if we ever got an ITR with that wing! Maybe go with an extended factory-style rear spoiler and call it a day, but that's just me. The rear wing looks kind of '*****' to me.
Old Jul 17, 2025 | 07:11 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Wing and big hood scoop are a minus
Old Jul 17, 2025 | 07:22 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Looks like the car's owner has a J.C. Whitney catalog.
Old Jul 17, 2025 | 07:29 AM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
It looks good. I like a cowl hood. Or a bubble hood. The rear wing doesn't fit. A 90-92 wing would.
Old Jul 17, 2025 | 01:27 PM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
I have a 3" fiberglass cowl hood because the engine doesn't fit under the stock one. It doesn't look bad, but every time I drive it I want to spend the big bucks for a port injection manifold just so I can put the stock flat hood back on.
Old Jul 17, 2025 | 01:44 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I'm partial to the aftermarket high-rise '82-'90 style spoiler on Camaros.
https://www.hawksmotorsports.com/198...s-motorsports/
Always thought the high-rise '91-'92 wing looked better on Firebirds.
Old Jul 17, 2025 | 02:47 PM
altiller's Avatar
Car: 92 Convertible Z28
Engine: 5.7
LOL...If I were to put a big wing...then go big with the Cobra R
Old Jul 20, 2025 | 08:37 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
IDK, I kinda like it
Old Jul 22, 2025 | 08:22 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
That wing looks similar to the MK IV Supra wing
Old Jul 22, 2025 | 11:08 AM
armyvman's Avatar
Engine: 350 5.7L V8
Yeah, that was the AI doing its thing. If we put a wing on there it would be stock high wing from the 90's model, or the 5" blade spoiler.
Old Jul 23, 2025 | 12:10 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I am usually a fan of stockish look stuff.
IMO, you can't go wrong with the two-tone rocker / upper contrast you have there that worked on earlier third gen Camaros. Play with the combo, or just do the lower in vinyl so you can adjust to your liking. That said, a lot of people are going to feel the monotone 90s are a more modern look that the two-tone.
I also think virtually all the 3G Camaro 16s are a great look but to keep current with tire availiability? Go 18s. Or the 18" GTA style from gbodyparts, which would go great with your black lower on the picture.
Spoiler? They tapered the Camaro style to look good with one. Go for it. A non-stock style that others think was stock is one way to approach it. Every stock spoiler had no molding lines. And nothing says you can't shorten standoffs. Find one the right width, smooth it, lower it, send it.
sfusco3
Jun 9, 2014 10:32 AM
Gumby
Feb 16, 2013 02:40 PM
White89Firebird
Jun 22, 2009 04:07 PM
'Shifter
Nov 9, 2006 09:10 PM
CraZ-28
South West Region
Sep 21, 2005 09:25 AM
