1985 Firebird window sweeper need replacement
Old Aug 2, 2025 | 09:42 AM
Robin1985fan's Avatar
Greetings!
New to the Forum.
My one-owner 1985 Firebird needs the outside window sweeper moulding replaced. It is hardened and cracking, one 1' piece broke off on the drivers door.Q: What is the best place to buy new ones? Q2: Are they hard to pull and replace?
Thanks everyone!
I need the curved black trim behind the chrome edge.
RN.
Old Aug 3, 2025 | 06:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1985 Firebird window sweeper need replacement
I got mine from A1 Auto
Old Aug 8, 2025 | 08:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
A bit of a PITA to replace, but not rocket surgery. Window is somewhat in the way when removing the screws that hold it on. The triangle seal needs removing too, mark its place for re-installing.
Old Aug 11, 2025 | 11:51 AM
Good morning all.
After watching a few You Tube videos on the outer door sweep replacement, i am ready to but parts and get it done.
Anyone buy from Classic Industries Parts and Accessories?
Several want to sell you all 4 strips as a kit, but only the outer 2 need replacement.
Looking for the best price and quality.
Thanks!
Old Aug 11, 2025 | 12:06 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I've used Fairchild recently with good experiences. available at Rock Auto. might beat anyone else's price?
Old Aug 11, 2025 | 02:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
I used A1 Auto good prices PLUS FREE DELIVERY
Old Aug 12, 2025 | 08:39 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Before u start removing the tiny screws and or reinstalling these screws, place a towel to catch the screws that fall off your screwdriver.
also, magnetize your screwdriver to hold onto the screws because it it a small space u have to work in.
Old Aug 12, 2025 | 06:04 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Removing the door panel and moving those window stops a bit wil ldefinetley help!
Old Aug 14, 2025 | 05:04 PM
Greetings!
Quick question:
ONLINE, I see 1A Auto and A1 Auto, with a local store here in St. Paul, MN.
Which one did you use?
Thanks!
Old Aug 14, 2025 | 11:10 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
They meant 1A Auto. I've bought from them before.
Old Aug 15, 2025 | 09:06 AM
BURD's Avatar
Yes. Remove stops, lower window. But it took 2 days to re adjust glass on my sec Gen, new strips threw it on a bad angle
Old Aug 16, 2025 | 11:45 AM
mantaguy's Avatar
Engine: 5.0 EFI
https://www.1aauto.com/1982-92-chevr...2/4131725/1985
88TransAmGuy
Apr 2, 2012 11:53 PM
theNMBR27
Convertibles
17
Feb 4, 2010 09:32 AM
Chevyz2882
Exterior Parts Wanted
Sep 29, 2006 07:23 PM
bad_ta_05
Dec 21, 2002 03:36 PM
