T-Tops leak so bad i got rust!
Old Feb 4, 2002 | 09:26 PM
ozzy28camaro's Avatar
I pulled the headliner off of carmen (my iroc) and the inderside of the roof is rusted and rotted from water leaks from the tops. what can i do for this bigg problem? is it fixable, i silconed in between the weathersriping and the body but it didn't help...im thinking about selling it and buying a hard top....any feed back is greatly apperciated...thanks guys
Old Feb 5, 2002 | 06:29 AM
custman87T/A's Avatar
fix the rust and order the GM kit to replace the T-top seals and all leaks will stop
Old Feb 5, 2002 | 07:05 PM
BlueAlice91bird's Avatar
I have a similar problem, my t-tops also have rust all along the front and back edge. Exactly how would you suggest this be fixed? Cut and Weld or that POR-15 stuff?
Old Feb 5, 2002 | 07:09 PM
360Iroc's Avatar
depends on ow bad the rust is...need more details
Old Feb 5, 2002 | 07:34 PM
the rust is bad....its morel like rot
Old Feb 5, 2002 | 08:15 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I doubt your t-tops were ever leaking. Most leaks come from the metal where the roof is in the middle and back. If you have water comming in over the back seats or even some places in the front this is probubly your problem. I'm planning on fixing mine this weekend with some 3M sealer compound. Go ahead and stick a garden hose on your roof and get in to find where those leaks are comming from, then use a sealer where it was leaking. I marked off all my spots and now I need to find something to seal it with.
-Matt
Old Feb 6, 2002 | 04:30 PM
My rust isn't as bad as ozzy's sounds. Just have several patch's on the edge of the metal. Of course I really haven't got in there to really look, kind of afraid of what I might find. So what do you suggest?
Old Feb 6, 2002 | 04:52 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
I would clean off the loose stuff with a wire bruch then cover it with some POR15. Then seal the metal where it leaks with some kind of sealer. I'd go to the local parts store to see what they have. I'm going to try and do mine before my baby goes in to get the body redone and paint Monday :lala: . I Can't wait!
-Matt
EDIT: ...typo...typo...typo...
Old Feb 7, 2002 | 01:52 AM
Blue502's Avatar
If its rot, you should really cut and weld. POR15 will stop it from rusting out more, but won't replace the missing sections of metal. Fiberglass or other quickie repair methods probably aren't a good idea there, since I would think that is probably a stress point (but if you can't afford to weld yet, a quickie job might hold you over for a little while).
Old Feb 7, 2002 | 09:18 AM
Boosted GTA's Avatar
Here's what i did on my 87 when i had baaad roof leaks:
After finding the rot in my roof, I did a patch, replaced the weatherstripping, and filled the entire roof with spray insulation foam. It expands as it dries so it filled the entire roof fairly well, and I never had a leak again. You can get the foam at your local hardware store, plus besides being a water sealant, it doubles as sound insullation too
Old Feb 7, 2002 | 07:57 PM
thanks guys im gonna grabb some fast cash and fix this crap...then mayb ill finally get that new paint and flowmaster 2 chamber.
Old Feb 7, 2002 | 11:54 PM
2vmodular's Avatar
check the seat tracks for signs of corrosion too. if they need replacement, get ones from a non-t-top eqipped car at salvage yard because they are usually in better shape.
xxx3man`
Sep 23, 2015 10:37 PM
neekolzun
Aug 24, 2015 04:59 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
3rdgenparts
Aug 6, 2015 09:03 AM
