I just broke a Lug Nut bolt :(
Old Feb 6, 2002 | 12:32 PM
GoldenSwordZ28's Avatar
I just snapped the lug nut and the bolt that it was on clear off my Camaro What is that peice called that the lug nut bolts are attacked to? And how much do they run? Its on the driver-side rear of the car.
Thanx guys!
Adam
Old Feb 6, 2002 | 01:01 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
lug?
you can get them from many different auto parts stores. might have to beat it out, or have it pressed out and in though.
Old Feb 6, 2002 | 01:21 PM
360Iroc's Avatar
that would be a lug and a stud
Old Feb 6, 2002 | 02:47 PM
EddieDellz's Avatar
heh that happend to me only i was in the mist of doing a burnout and all the bolts came off . needless to say new disk and calipar ect... was funny tho if you can laugh at it it was worth doing
Old Feb 6, 2002 | 03:13 PM
Heh, well, I've always driven around with one lug missing from each wheel, when I bought the car it had a locking lug on each wheel... and they took um off and never gave um to me, didn't know anything bout that then though. So I finally went and got and entire set. But last night I was trying to install my Shocks and Struts I got, and it was like 2:30 in the morn and I was trying to turn it the wrong way...... and it didn't wanna go. So I kept trying, and finally, POP! I was lieing out in the middle of my driveway on my back, and knew exactly what had happened. So I just layed there for like 10 mins wondering what I was gonna do. So then I got up and pulled a lug out of my new set and had to get my bearing back.... so I spun it both ways on the Stud.... and I had been pulling the wrong way. So, now the stud is gone..... and I need ta get somthing to replace it..... what is it I get? Heh, I finally gave up on the Struts and just put the back shocks in (Broke another bolt in-half back there, but it was what was holding the shock into the bottom brace, and my new shocks came with a new one... so it was ok ) and its nice but, It still feels ULTRA nasty in the front, and it sucks. BTW, the old shocks in the back just kinda fell closed and never came back up Thank *** I got the new ones. Tonight! I attempt the Struts again! (Have ta figure out how to get the damn Caliper off, only thing I got is an alan wrench that BARELY fits. And can't get and tourque on it.) And this time, MORE CAFFINE, so I can remain coherent!
If you can tell me what I need to do to replace the stud, I'd appreciate it!
ThanX
Adam
Old Feb 6, 2002 | 03:17 PM
EddieDellz's Avatar
take off the calipar and brake hammer out the old stud get a new one from autozone itt should be like a buck the studn and bold and to presss it back in sinc eyou dont have a press just tighten the bolt on .. try night to over do it you could brake the new one an dhave to start agin
Old Feb 6, 2002 | 03:35 PM
ThanX Man, I'm gonna go out and grab one after I get outta work here! I appreciate it
Adam
Old Feb 8, 2002 | 12:51 AM
360Iroc's Avatar
you dont need to remove the caliper to take off the front shocks, thats a waste of time for ya
Old Feb 8, 2002 | 07:49 AM
okfoz's Avatar
When you replace your front shocks, you might consider getting an alignment for safty purposes...
John
Old Feb 8, 2002 | 10:22 AM
camaro6spd's Avatar
HA, at least your stud snapped.....you get get new ones pressed in farily cheaply. My lugs got stuck on there and it to 10 sec of pounding from a 3/4 impact gun to get one off, then a breaker bar with a 5 foot pole and some serious pounding from a hammer to get the last one off. I spend over 2 hours trying to get the front lugs off my car. Take it from me. Go the auto parts store and buy some good SOLID lugs, not the ones with the crappy tin covers like our stock lugs.
EDIT: just read the rest of your post...I STILL THINK YOU SHOULD DO THIS...save you from future headaches.
Old Feb 9, 2002 | 04:08 AM
Jza's Avatar
Jza
Old Feb 25, 2002 | 09:16 PM
mechanicalmehem's Avatar
i did that on all of them on my truck it sucked, i just hammered them out and back in, no biggie
Old Feb 25, 2002 | 10:25 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
Oh yeah i had an idiot friend put my lugs back on my buick daily driver.......he used the impact wrench and cross threaded one........now i can bench press 390 pounds and i u sed the breaker bar and five foot pole thing......no use.................wound up drilling the damn thing off..........needless to say never let an idiot friend help you with you r car.......then again maybe i was the idiot for letting him near it with an impact wrench
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
fasteddi
Sep 10, 2015 09:32 AM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
