Where is the fuse for my Power Windows??
Old Feb 9, 2002 | 09:52 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
?? :lala: :lala:
Old Feb 10, 2002 | 01:00 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Try the accessories fuse, thats my guess.
Old Feb 10, 2002 | 01:24 AM
2vmodular's Avatar
it's not a fuse, it's a circuit breaker. Are two circuit breakers in fuse box under drivers dash one is for rear window defroster and power locks, the other for power windows.
Don't be suprised if one breaker is nowhere to be found, they can get loose over time and fall out of their socket.
Old Feb 10, 2002 | 11:58 AM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
How do they look? Do they look like larger metal fuses? If so, i found them, and they are not the problem. What would prevent just my power windows from not working? This happened all of a sudden.Every other electrical thing works except these two windows. I need to roll them up so my car does not get broken into. Please HELP!!!
Old Feb 10, 2002 | 01:23 PM
Black85TransAm's Avatar
Just an idea buy maybe ur motors are shot.......aslo , take the center comsole out and check the wiring.....
Old Feb 10, 2002 | 06:00 PM
2vmodular's Avatar
it's very unlikely that both window motors themselves would suddenly fail at the same time.
more likely there is something wrong with the wiring or switches going to the motors.
Have you tried swapping locations of the two metal cased circuit breakers on the fuse panel? If power windows suddenly come to life, but power locks no longer work after the swap, you've found your problem.
If no sucess swapping breakers, start probing around with a voltmeter. Should have power at one pin of the WDO circuit breaker socket when ignition key is turned on. Power should also be present at a terminal on each window switch.
Old Feb 10, 2002 | 06:17 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
Fixed em, i swapped the metal breakers. now, how do i reset the thrown switch??
Old Feb 10, 2002 | 06:36 PM
2vmodular's Avatar
it's supposed to automatically reset after a short period of time. sounds like the breaker has failed and is in need of replacement.
Old Feb 10, 2002 | 10:01 PM
Convert's Avatar
Car: 1987 Iroc Z
Engine: 5.7L TPI
Hmm, where the heck do i get one of these?? Would a place like autozone have em?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
