Entire Interior Removed....
Old Feb 17, 2002 | 02:50 AM
GoldenSwordZ28's Avatar
Now that I got the interior removed, which I did so that I could check on the condition of the body underneath the carpet and so that I could also wash everything.... What else should I do while its all up? Anything that would be worth my while? Somthing I had thought about was that sound-silenceing matting.... I can't remember the name of the stuff but It couldn't hurt to make things a little quieter Can you get that kinda stuff at a Lowes or Home Depot? Gotta go clean the hell outta everything tomorro..... later today Just wanna know what you guys think I should do while I got all the stuff out, ANYTHING at all useful would be of great service!
Adam
Old Feb 17, 2002 | 06:30 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
I'm in almost the same phase you are. Pull up all the jute padding (carpet padding). I found that everywhere I had this stuff, I had rust starting. That crap just retains moisture! I'm gonna spray rubber undercoating where I removed it, to help with sound deadening. Once I get that done, the new carpet and seats can go in!
Old Feb 17, 2002 | 10:13 AM
MoDiPhYd's Avatar
I just did this yesturday! LoL I pulled out EVERYTHING. under my headliner in the back on the inside and outside near the passenger hatch bolt I have mad rust. Im doing body work to it all. and before I put everything back in, Im lining my roughed up grey interior panels (ones I can salvage) with black vinyl, as well as the headliner and theres a lot more custom work going to be done with the interior... I'll post pics and everything when Im done, but.. I need to finish the exterior first! my poor cars life is just starting
Old Feb 17, 2002 | 01:12 PM
Drew's Avatar
Replace all the plastic interior clips, they're cheap and will go a long way towards reducing rattles. Also be sure you put the interior back together correctly.
Old Feb 17, 2002 | 09:27 PM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Make sure you kill all the rust before spraying on the undercoating... The undercoating won't stop the rust and it'll just keep eating away at the floor!
Rob
Old Feb 17, 2002 | 11:38 PM
Damn that rust!!! Yeah, I got rust to man, and why the hell is that padding wet?? It hasn't rained here in a while! Well, I started sanding away at the drivers side floor area (Not making GREAT progress but at least theres no hole there). Rear passenger side however, is another story. In the Rear passenger foot rest area I have a crack, a rusty crack. Its not huge or anything, but its a crack none the less, so I gotta cut out around it and have somone weld in some replacement metal. Whats this POR 15 stuff I keep hearing about? Heh, I gotta go to work tomorrow, so I just went and bolted in a seat and a seat-belt Theres no law against having no carpet or Passenger seats, Right? What should I use to kill the rust for good, and what kinda paint can I use in there? Well, gotta take the dash out after I'm done with all this work on the floor, then I gotta order new Carpet, mine is NASTY. Well I'll keep ya posted as ta whats goin on!
You other guys/gals that are doing it as well, keep me posted to!
Adam
Old Feb 18, 2002 | 06:17 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
por 15
Rob
Yup, I used that too. Hope I did it right, though. I've read about a metal prep that supposed to be used before the paint, but it was too late already. Do a search for por15, there are several posts here about it.
Old Feb 19, 2002 | 04:19 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
im in the same step of my restro.. defiently replace all the plastic clips.. im repainting all my plastic trim pieces. they look like they were origionally black then painted blue.. now the blue paint is chipping off.. new carpet.. new headliner (mine was destroyed and cant be redone).. umm.. cant think of anything else off the top of my head..
mike (loomdog)
Old Feb 19, 2002 | 10:39 PM
91z4me's Avatar
If you wan't sound deadening get Dynamat. Not only is it a sound deadener but it is heated and seals completely with the metal. On the down side once it is on it DOESN'T come off. Check out DJSexey's site he did Dynamat Xtreme all over his car. It looks really good too.
Old Feb 20, 2002 | 02:25 AM
loomdog32's Avatar
Car: 82 Camaro Z28
we could probably get into a discussion bout this for days, but dynomat Xtreme is the best u can get. but it would cost u bout $1k to do the whole car ($250 retail per bulk pack and u need at least 4 for the whole car). rammat is alot cheaper and will give close to the same results for a lot less.. u could double rammat and still be cheaper than dynomat and get the same results if u really wanted to.
https://www.thirdgen.org/techbb2/sho...767#post528767
check that out for the comparision DJSexy did between dynomat and rammat.
mike (loomdog)
Veaceonee
Sep 29, 2016 08:15 PM
RyanJB
May 7, 2016 06:23 PM
MORREALE5
Sep 13, 2015 09:01 PM
sylentnite
Sep 9, 2015 02:55 PM
scottmoyer
Sep 7, 2015 07:06 PM
