How to Break into a third gen.
Old Mar 21, 2002 | 08:29 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
No not for the purpose of stealing one or thiefing radios. But I was just at pep boys buying a open element air cleaner and I locked my keys in my car SOB!! I yelled. Heh, there was a home depot there so I walked over there and bought this rod. Bent it like so and unlocked the door. Ha what a piece of cake. Anybody else use some other way to get thire keys out of thire locked car?
Old Mar 21, 2002 | 10:49 PM
Bird_of_Prey's Avatar
Car: Formula
Engine: 400 sbc
pull window (driverside) back, didn't lock t-tops.. opened one and i was in.. then i retightened the door things that push on the window when it's up..
Old Mar 21, 2002 | 11:15 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I like the "spare door key in the wallet" method.
Old Mar 21, 2002 | 11:25 PM
2vmodular's Avatar
there's no sheild around the latch mechanism in thirdgens. by contrast some other cars have metal plates around latch to discourage theft.
personally, i found installing keyless entry greatly reduces the number of times i've locked the keys in the car. got in the habit of hitting the lock button on the remote when i exit car, no remote in hand can't lock door and must have left keys inside the car. all the effort of adding power locks to a non-power lock equipped bird appears to have been worth the work.
might also want to check out:
http://www.taplock.com
sounds like a neat toy, i've got one on order.
Old Mar 21, 2002 | 11:31 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
very simple. Take a rod of some sort, and if you have your t's unlocked, just push in with a rod or stick, and voila, t-tops are unlatched, and acces to the car is easily gained.
Damn, I need to get the locks on my t-tops fixed
Old Mar 22, 2002 | 12:01 AM
I have heard of pulling the window out then unlocking the t-tops. But I just have this fear of that window breaking and cutting my wrist !! that would suck. You know the last time I did this I swore that I would get a door key in my wallet. TOMORROW I get one! No more for me.
Old Mar 22, 2002 | 04:10 AM
mcconahay37's Avatar
You do this often? :lala: :lala:
I've only locked my keys in car once, and now I always have a spare in my wallet. My car had broken down, and I had given up on trying to figure out what was wrong with it in the parkign lot. Get ready to go call the tow truck, lock the door, shut it, and realize my keys were still in the ignition. So that added another $15 on top of the tow fee Now, I always have a spare in my wallet.
Old Mar 22, 2002 | 10:04 AM
camaro6spd's Avatar
ZIP TIE KEYS IN A ZIPLOCK BAG UNDER THE CAR....I done this to ALL of the 2 cars I owned in my life...LOL well seriously my father has me get keys made and I place them under all the cars my family owns....Had to use them several times over the years.LOL
Old Mar 22, 2002 | 11:00 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
These work also
cant go wrong with one of these. I have these 2 spairs not cut to match any keys yet. Just like a credit card in your wallet.
Old Mar 22, 2002 | 11:07 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Where do you think I got my thirdgen j/k
I carry two keychains at all time... one with ignition and door... the other just a spare door key... I've already had to use it just within a month of implementing the method... saved my *** from sitting frozen out in the parking lot waiting for extra key...
Old Mar 22, 2002 | 11:44 AM
Absalom's Avatar
Car: 83 Camaro Z28
I realize getting a second door key is more than likely easier, but where did you get the credit card style extra keys?
Old Mar 22, 2002 | 12:55 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
On my 86, just about any 80's to 90's chevy door key will unlock my doors and hatch. My old boss has a 83 1 Ton which will do this. Other numerous friends cars are the same way.
Also one try with the slim jim does it every time. I have one hid out by the radiator just in case. Guess I'm too cheap to get a key cut, or just lazy.
Old Mar 22, 2002 | 02:41 PM
1982chevycamaroz28's Avatar
that rod is just like what towing companys use when u lock ur keys in ur car. but theres is coated in like a plastic dip and whatnot.
Old Mar 22, 2002 | 04:18 PM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
Yea, that's the one I use...
Althought mcgyver would tell you that the task could be accomplished with a piece chewing gum, a string, and a AA battery.
Old Mar 22, 2002 | 07:52 PM
i think he could get in faster with a tic-tac, piece of hair, and a bowl of water. lol
Old Mar 23, 2002 | 08:54 AM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
What if you're a real bad aim with the string, bubble gum and AA battery? I don't want bubble gum all over my seats!
Old Mar 23, 2002 | 10:07 AM
Hobbs85's Avatar
I had a friend give me the best idea yet? I made a extra key for the door locks and drill a hole through the end, and remove the rear license plate, placing the key behind the plate, and screwing the bolt back in. This way if you lock your self out, all you need is some loose change to unscrew the license plate bolt and your done. JUST KEEP SOME CHANGE? Surely someone will have some change... I have done this with all my vehicles.
Old Mar 23, 2002 | 10:41 PM
Re: These work also
Where can you get one that says pontiac, dealership?
btw, no I dont do this often just twice then I'll learn my lesson. Heh think I disturbed some people in the parking lot curseing so loud. hehe
Old Mar 24, 2002 | 02:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got 2 sets of the plastic ones, both say Pontiac on them.
One is a blank set and the other was cut for my Pontiac Sunbird.
Old Mar 24, 2002 | 09:56 AM
TransAm's Avatar
Well, obviously, in that case you use the tic-tac, piece of hair, and a bowl of water method.
Old Mar 24, 2002 | 03:43 PM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
The fastest and most efficient way is to use a BRICK.
Old Mar 24, 2002 | 03:45 PM
TransAm's Avatar
Anyone seen gone in 60 seconds? "I've gotta get my tool..."
lol
Old Mar 24, 2002 | 10:32 PM
sllt1776's Avatar
Car: 89 Iroc-Z
yea i'd have to say the brick method works fine and if it's a nice day you won't have to put the windows down after.
Old Mar 25, 2002 | 03:47 AM
88_RS&86_Z-28's Avatar
mine is probly the easy way since my car only goes out in the summer time and i always have the T's out i just don lock the doors and leave the windows down
or you could always just hide a key somwhere and on our cars there are penlty of spaces
gas cap
under front clip
behind the plate front or rear
wheel well
under rear bumber
hell even those vents in front of the wipers
Old Mar 25, 2002 | 09:23 AM
traumatech's Avatar
I use duct tape and put a spare key up between the floor and tranny. If someone else has the ambition to crawl under and get it, they deserve to drive my car. And working that hard to get it myself reminds me not to do it again for at least a few months. Good thing I'm one of these skinny punks.
Old Mar 25, 2002 | 04:44 PM
HamsterOnaMission's Avatar
are those plastic things actually keys??? where do you get them?
Old Mar 25, 2002 | 08:57 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
Howabout some a can of mountain dew, a bike seat, and an airfreshener?? McGyver is the MAN!!!
Old May 11, 2002 | 11:39 PM
Trans-Am 88's Avatar
How about this:
Get a long stick (broomstick etc..) pry the passangers side window out a few inches and hit the hatch release button on the dash if your car is equipped w/ it. Takes about 10 seconds :lala:
Don't ask how I know this... OR why I am soaking wet right now
Old May 11, 2002 | 11:56 PM
89Formula305's Avatar
I used the 2 paint sticks an antenna and a nut method..lol
well heres my story, i went out to start my car and my door locks are frozen up and the battery was dead so i couldnt use my keyless entry.
i got two paint sticks and stuck em in the window to hold it open, then i got an antenna and screwed a square nut on the end of it. Then i just stuck the rod inside and put the nut in the slot where the lever is and slid it over...
Old May 12, 2002 | 12:32 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Keyless entry is a GOOD GOOD THING. I never leave my car without pressing the remote, therefore locking the car. Course it doesn't help if you don't have power locks.
Old May 12, 2002 | 07:26 PM
SlowStangEater's Avatar
Mine is simple and easy..............No drilling,taping,ziptying, THROWING OF BRICKS .................I simply put my spare key in the key hole for the trunk,lifted my license plate back up and PRESTO....................I dont think a thief is going to check there! But if he does..........Well then hes got to get past Various Deterants!!!! Besides I sometimes wish my car would get stolen...
Old May 12, 2002 | 07:49 PM
CrazyHawaiian's Avatar
Car: too many ...
yes actually I have done that hehhehe. I used a door stop to hold the window to the side while I fished with a hanger. It was a good lesson. Now that I know, my next Camaro is getting the windows and windshield tinted so dark it will be impossible to see inside the car. I will also have shaved handles and relocated locks.
Old May 12, 2002 | 10:49 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I don't know about anyone else, but on my bird, I can crawl under the nose, reach up and pop the hood. So, I just hide a door key in the engine compartment. Then, the ignition is hidden in the interior. So... you can get lucky and find the door key...but wait. You have to find another as well. I've locked my keys in the car a few times. Then I finaly came up with this plan.
It was devised a little too late though.
Old May 13, 2002 | 03:51 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Originally posted by Trans-Am 88
How about this:
Damn, I was hoping to be the first to post this method! I had to do this once, but I used a fishing pole and hooked the end of it on the hatch release. Presto! Worked like a charm!
Old May 13, 2002 | 09:53 AM
MX265
Guest
Posts: n/a
Advance Auto Parts sells Slim Jim's for $7.00 in the HELP Section.
Old May 14, 2002 | 07:46 PM
Absalom's Avatar
Car: 83 Camaro Z28
Why do I find so many posts about how to get into my car disturbing?
Old May 14, 2002 | 09:40 PM
IneedaFbody's Avatar
i learned a pretty easy method. . if you are skinny. just pull back the driver or passenger side window and slip your arm in and unlock the door. i can do it fine but i had a friend who was a little thicker than me and got some bad bruises on his arm from doin it.
Old May 14, 2002 | 11:05 PM
Beene's Avatar
I found that after I had my windows tinted at 5% and tightened up the bolts that hold the window up I couldn't get anything in there. Keyless entry all the way!! It's easy to put it in a non power lock car too!
Old May 16, 2002 | 10:18 AM
Mshrmhd's Avatar
Car: 91 Z28
Engine: F 305-205 (LB9)
this is kinda funny, i just locked my keys in my car last night i had a ticket to see mushroomhead in the console and my ride came and i couldnt get in my car...
all i did was took a coat hanger , straightened it out abit, twisted the end so it made an L shape, slid id between the weatherstripping and window right over the key hole, pushed down , and i was in.
l
l
l
l
l
l
l_____ kinda like that , i guess.. haha
but in a few hours, im going to wal mart and getting 2 door keys made for it. ill leave one at home , and one in my wallet .. maybe 3 keys , get one of those spiffy magnetic key holders and put it under car somewhere. hmmmm
Old May 19, 2002 | 01:50 AM
Shibbyfbird's Avatar
i found myself there once, i was wrenching on my S-10 awhile back, i had a pizza in the oven, my door got locked to the house, i locked up the s10, with the keys inside. I looked around the backyard and found a flyswatter, twisted it apart, slid it into the window of the truck, and the flyswatter slid inside the window, never to come out again. needless to say i had to break into my house and ordered a pizza after i put the fire out from the one that was in the oven for a few hours, lol. I now i keep a spare key to my firebird in the toolbox and my wallet.
Old May 19, 2002 | 07:24 AM
You know what I could do.... Leave the doors lock all the time. Get a needle full of what ever. Place the needle in the seat. Then when the theif sits on it, it will inject them full of krap. When I come to the car and find some theif passed out in the driver seat I can beat his a$$ wheile he is asleep throw him in a dumpster and let the garbage man do the rest.
Old Jul 20, 2005 | 08:18 PM
  #42
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Sorry to ressurect a thread but thats halarious!
Old Jul 20, 2005 | 09:45 PM
  #43
KissThis's Avatar
Car: 1984 Firebird V6
Well, know that I know where you all keep your spare keys ::checks to see who has the best car and is the closest::
We have a lock pick set and slim Jims in every car and my husband has keys to all my cars and vice versa. We always double check with each other to make sure we have keys in hand. there are also door keys stashed around the outside of the car.
We did this ONCE with the house keys. That was NOT fun
Old Jul 20, 2005 | 10:36 PM
  #44
Dirtbik3r's Avatar
Good thing you're not neer me. New Mexico to New York... lol
Old Jul 21, 2005 | 12:03 AM
  #45
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
I did it at work (Lowes)... I went inside and cut a piece of metal band from the bander .. shoved it down where the lock was and it unlocked first try. Disgusting how easy it was... might as well leave it unlocked.
Old Jul 21, 2005 | 03:09 AM
  #46
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
I keep a door key in my wallet, one at home, g/f has one, and my mechanic has one.
Old Jul 21, 2005 | 04:44 AM
  #47
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
i see one preson in that who shouldn't, can anyone take a guess who it is?
Old Jul 21, 2005 | 07:08 AM
  #48
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
g/f O:-)
Old Jul 21, 2005 | 08:46 AM
  #49
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
i found that some other thirdgen keys worked in the doors of other 3rd gens sometimes.
Old Jul 21, 2005 | 08:54 AM
  #50
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
atleast bringing back this old thread was worth something....
ive never heard of that, but its pretty cool.
