How do you strip bumpers
Old Mar 29, 2002 | 08:36 PM
89blackbird's Avatar
My bumpers are repainted by someone who used regular car paint with no flex additive. Yes they are all cracked and I need to strip the paint off and do not want to hurt the rubber. Any ideas how? Will regular stripper hurt the rubber?
Old Mar 29, 2002 | 09:18 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I believe that you have to get stripper that is made for urathane bumpers. If you use regular stripper it will seep into the urathane and whenever you try to paint it the paint wont stick.Or use a da sander to take off the paint.
Old Mar 29, 2002 | 09:24 PM
1982chevycamaroz28's Avatar
i used a feather edger on my rear bumper to get the paint off and it worked good untill i hit like the tight spots. yes number 300 post.
Old Mar 29, 2002 | 10:35 PM
orange rocket's Avatar
I just bought sherwin williams bumper stripper. As stated above their is special bumper stripper
Old Mar 29, 2002 | 11:29 PM
Blue502's Avatar
SEM also makes a flexable parts stripper available at most automotive paint stores
Old Mar 29, 2002 | 11:35 PM
FoREEL's Avatar
Use a DA Sander with say a 180 grit.
Old Mar 30, 2002 | 06:46 AM
I will check on the bumper stripper. My car is also black.Yours looks good. What kind of paint??
Old Mar 30, 2002 | 05:52 PM
Car: 85 Camaro SC
Engine: V6
Thanks, its called Nason 1 stage paint made by dupont. I really like how most of the orance peel has gone away. And compared to the last paint job with the same kind of paint mine came out 4 times shineyer and way less orange peel.I just stand back in awe cause I cant believe how good I painted my first paint job.
Old Mar 31, 2002 | 07:54 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I would follow the DA with 180 post. While you are removing the paint you are also preparing the surface and removing minor blemishes. The stripper won't do that in one step.
Then prime with a high build primer/ wet sand/ and shoot with a quality paint. Most of todays paints don't need the flex additive but you can still get it.
mcfastestZ28
Oct 5, 2015 07:12 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
