Brake line question
Old Apr 5, 2004 | 05:40 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
Brake line question
I'm going to be doing a rear end swap in a few weeks. Instead of bending and flaring the brake lines can I get some braided stainless steel lines from somewehre??? (the lines that go from the brake drum to the center of the rear end) Has anyone tried this before? How did it work?
Old Apr 5, 2004 | 07:14 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What exactly are you doing? A rear end swap or a brake swap on the same rearend? just clear this up for me and I'll chime back in.
Ed
Old Apr 5, 2004 | 07:48 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
I'm swapping out the original 10 bolt open rear end and putting a rebuilt 10 bolt with posi+3.73's from a 91 Z. I would like to replace the stock brake lines with a braided stainless steel line. I have a feeling that I will not be able to get the stock lines off in one piece. Hopefully this will clear things up for ya
Old Apr 6, 2004 | 06:04 AM
ebmiller88's Avatar
OK then...You'll need the rear lines from Earl's 1LE set, P/N 28A190. Those are just the 3 flex lines so if you also need the hard lines, look at Inline Tube, Classic Tube, or Fine Lines, Inc. All offer new hard lines for $30-50 that will fit that rear.
If you're worried about getting the lines apart safely, soak the hell out of them with a good penetrant like Kroil or WD-40 for 3 days prior to removing them (twice a day at least), and be sure to use flare nut wrenches when trying to get them off so you don't round off the fittings, and they should come off just fine.
Ed
Old Apr 9, 2004 | 12:54 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: Tire Chirpin A4
....and if they don't? Can you just cut it and add a new fitting and reflare if you have a lil line to spare?
Old Apr 9, 2004 | 05:39 AM
ede's Avatar
ede
sure the lines can be reflared, make sure you use the corrct flare
Old Apr 12, 2004 | 01:57 AM
Pat Hall's Avatar
I don't think I'd use flexible braided lines all the way from the pumpkin to the wheels anyway. You'd probably have to use zip ties or something to keep flexible lines close to the axle tubes without flopping around. It's better to run regular hard lines along the tubes until you get to the ends, then run the braided lines there.
Old Apr 13, 2004 | 10:32 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
so do they sell a prebent and flared section for the rear of the car? cause my main rear line rusted out and i need to run a new one. but i dont wanna go through the BS of bending all the lines in the back.
Old Apr 13, 2004 | 11:42 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
It's like $40 from classic industries, but the shipping is what kills you because they have to ship it oversize so the shipping ends up being almost as much as the line.
Old Apr 13, 2004 | 11:54 AM
F-Bobby's Avatar
so they do sell the rear section?? sweet!! do they have a website or somewhere where i can order it?
Old Apr 13, 2004 | 09:28 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
www.classicindustries.com
Old Apr 14, 2004 | 04:07 PM
F-Bobby's Avatar
ok i went there but which catalog is it in. there isnt one that specifically says brakes. i have however found a lot more info on there that i was lookin for anyway. thanx for the link.
Old Apr 15, 2004 | 04:31 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
I can dig through my catalog here for the PN# if ya want?
Old Apr 22, 2004 | 03:36 PM
F-Bobby's Avatar
yeah dude if ya coudl get the part # for me i woudl greatly appreicate it. im not gona have time for this other BS
Old Apr 22, 2004 | 08:00 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
87 formy right? PN# FIN8601 for original material or FIN8601S for stainless.
Old Apr 23, 2004 | 12:10 AM
F-Bobby's Avatar
thanx dude, where is that in the catalog incase i need to find it.
Old Apr 23, 2004 | 12:37 AM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
You can DL the catolag, or get it in a papaerback and even in CD rom now from classic. Just go to thier web site get the 1 800 number and give them a call.
Old Apr 25, 2004 | 06:17 PM
F-Bobby's Avatar
well i tried to punch in the part number ya gave me into their online catlog and it doesnt have it. its got something else that may work, but im not sure, its like steel oem line but there was somethgin about it that wasnt right, i dont remember what it was.
Old Apr 25, 2004 | 10:47 PM
irocet305's Avatar
Car: 91 Z28
Engine: L98 350
The number I gave ya was for a camaro line....same thing....maybe there is a difference in years between disc and drum, but as I recall I don't think disc or drum matters. Dude just take 5 minutes and call them.....
Old Apr 27, 2004 | 05:41 AM
F-Bobby's Avatar
ok thanx.
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
