brake plumbing
Old Aug 3, 2004 | 10:08 PM
sleeperZ28's Avatar
Car: 86 z28
Transmission: built 700R4
brake plumbing
i am going to be swapping a 4th gen rear into my 86 z28 which requires an adjustable prop valve. i am also going to plumb in a line lock on the front brakes. my question is do i still need to have the factory metering/prop valve or can i just take them out and run straight off the master cylinder?
Old Aug 4, 2004 | 04:46 AM
ede's Avatar
ede
the 4th gen rear doesn't require an adjustable proportioning valve. if you have the flat sided valve now you don't need to change anything. running the factory valve and an adjustable one wouldn't be the thing to do, one or the other, but you do need a porpotioning valve.
Old Aug 4, 2004 | 02:31 PM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
I do not follow....flat sided valve??
Old Aug 4, 2004 | 10:22 PM
sleeperZ28's Avatar
Car: 86 z28
if i swap from the 86 drum rear to the 4th gen disk rear i dont need an adjustable prop valve? everything ive heard says i need one. what about the front brakes?
Old Aug 4, 2004 | 11:04 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
just get a proportioning valve for a rear disc car. then you dont have to worry about bending lines, flaring them, re flaring them when they leak. spend a little extra and get a slp line lock that comes with lines and wiring, otherwise the same will apply as the prop valve
Old Aug 5, 2004 | 10:08 PM
sleeperZ28's Avatar
Car: 86 z28
the reason im asking is so i can get rid of the factory prop valve and all assiciated bent lines, then run new lines for the adjustable prop valve for the rear and the line lock up front. my intent is to make this a cleaner looking install rather than adding more lines and leaving the factory prop valve. will the line lock and adjustable prop valve distribute fluid the same as the factory valve does or is there some reason to keep the factory valve?
Old Aug 6, 2004 | 06:48 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
now you do realize there is a reason for the length of the tubing correct? hydralics 101 length must be the same or you will have diffrent pressure at each brake.
anyone hear of this also? i'm no expert but have asked questions in the past on older progects.
Old Aug 6, 2004 | 10:11 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
that is incorrect, in hydraulics, the line/hose length is NOT a factor(other than possible hose swelling) in pressure drop
with a non metered/restricted line, the pressure applied at one end will be the same at the other, as long as no air is present...why you ask? fluid does not compress!, air/gas does
Old Aug 7, 2004 | 02:47 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Originally posted by Dave Y
that is incorrect, in hydraulics, the line/hose length is NOT a factor(other than possible hose swelling) is pressure drop
I'll second that. the only way you lose pressure is to have something compress or expand. Thats why you need to remove all the air from your brake lines (air compresses), and also why people run braided stainless lines instead of the stock rubber ones that can expand some and cause pressure loss.
Oh and as stated before if you are going to run an adj prop valve, you don't run the stock one too.
Chris
Old Aug 8, 2004 | 12:51 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Whoa...this is news to me. I'm in the middle of a 4th gen swap and all that's left is brake line work. I was going to just rip off the lines on the LS1 rear and make my own to go from the calipers to meet in the middle to use the 3rd gen T connector. I also bought an adjustable prop valve from Summit (the one with one input, one output, and a ****).
Are you saying that I can remove the stock valve...run lines straight from the master cylinder to each of the front brakes, and then just put the adjustable valve in-line with the rear brakes? I guess it makes sense.. I never thought about that.
Oh, and also, as stated above is correct. Line length means nothing..
Old Aug 8, 2004 | 01:08 AM
Car: 92' RS
Engine: LO3
No, you dont run lines strait from the MC to the front calipers. The prop valve splits the pressure between the front and back brakes. It is the next thing in line from the MC, DO NOT run a line directly from the MC to the calipers
Old Aug 8, 2004 | 01:10 AM
Car: 1997 Corvette
Then why did somebody say to get rid of the stock proportioning valve and replace it with an adjustable one... or is what I bought not really a proportioning valve..it just limits the pressure in a line?
Old Aug 8, 2004 | 01:37 AM
Car: 92' RS
Engine: LO3
You replace the stock one with the adjustable one. Wait, I just reread your post, one in and one out? Thats not a prop valve, it does sound like a pressure limiter. Guess I should have read more closely the first time. I don't know what you would do with what you got.
Old Aug 8, 2004 | 01:39 AM
Dave Y's Avatar
Engine: 4.3L V6
lots of guys run the line from the master to a line-loc, then strait to the front brakes
the rear goes from the master to a adjustable prop valve, then the the rears
our stock prop valves do not do anything to the front pressures, just the rear, since rear drum brakes need less pressure to work
but, it you do away with the stock valve, you lose the brake pressure warning switch functions
Old Aug 8, 2004 | 03:58 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm surprised no one has mentioned this. To keep my stock prop valve I just gutted it(rear side) and ran the line to the wilwood adj prop. The front lines go from the stock prop valve to the line lock and custom braided line to each front brake. I need to bleed the system again though. Seems kind of squishy.
Old Aug 8, 2004 | 07:57 PM
sleeperZ28's Avatar
Car: 86 z28
Dave Y i agree with you. that was my original thourght, so would you say i can ditch the OE prop valve and run the line lock and adjustable valve and be ok.
Old Aug 8, 2004 | 09:00 PM
Dave Y's Avatar
Engine: 4.3L V6
Thats what I plan on doing when I do my C4 front/4th gen rear upgrade
Old Aug 10, 2004 | 11:14 PM
sleeperZ28's Avatar
Car: 86 z28
thanks for the help
Old Aug 10, 2004 | 11:50 PM
Car: 1997 Corvette
With this setup, the brake warning switch/sensor would still operate correctly, no?
Old Aug 11, 2004 | 05:16 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Yeah, I guess I left that out. That's why I did it like that so that I could keep the stock BRAKE warning light functional if I ever have any problems or if for some freak chance I let someone else drive my car (yeah right...)
Old Jun 17, 2006 | 12:03 AM
yallwatchthis's Avatar
Car: 84 Z28
Engine: 355 vortec, super victor, 13.5:1cr
Transmission: 'glide
Axle/Gears: 7.5" 10 bolt/4.56 gears
I appologize if I am re-asking a question, but i have searched and can't find answers...I am in the middle of plumbing the brakes on my 84 Z28 for drag racing..hard lines from m/c to l/l to prop to frame mounts to stainless braided tfe w/ -3AN fittings on stock calipers. what size is the brake line and/or the fittings...i am having trouble gathering all the peices. I can build it all if need be, but what materials do i start with?
Old Jun 20, 2006 | 10:45 PM
Car: 84 Z28
what size fittings on the 84 m/c. what size fittings on the 82m/c. the 82 came with drum rear and v-6, will that m/c work on the 84 z28 four wheel disc with minimal or no pressure difference...prop not a problem..aftermarket will be in order
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
