82-88 and 89-92 front rotors the same?
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I'm talking about the standard front rotors, not the 1LE's. I understand the rears are different, but I thought the fronts were all the same.
The reason I ask: I saw on eBay that some vendors are selling drilled/slotted front rotors for 82-92 and some have listings for 89-92 only.
My '83 has a chewed up front rotor and my friend with a 10K orig mi. '91 Z28 just put SSBC brakes on it. He said I could have his old rotors & calipers. Just wanted reassurance that the rotors will fit. I don't think the calipers will work because 82-83's had standard fittings and 84-up is metric (if my memory serves).
Car: 04 Vette
THe rotors will fit and the calipers amy well fit too because it is a banjo bolt fitting and not a flare on the calipers. I am not sure I would mess with used calipers though when remans where only about 15 bucks tha last time I checked.
Engine: 4++,350 & 305 CIs
I think the diff is in the studs...When did they switch to metric from standard was it 84-85???? I'm not sure though
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by JDF-Z28
82-83 standard brakes 84 up metric.
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Originally posted by Apeiron
That's for the fluid fittings, not the studs.
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I tried to put a 91 Z/28 16 in front wheel on the same place on an 84.
I did not fit. The reason was that the hub on the rotor wher the bearing go was about 0.015 thicker and the taper was diffierent. This was enough to keep the wheel from properly seating.
This may be a fluke as I have had these wheels on other cars and the 84 may have had some part house rotor on it .
But there was a slight diffierence that I would have never thought to ckeck for.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
