post your brake pics (not stock)
Old Jan 9, 2005 | 04:50 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
here is my 13" baer brakes and 12 " rears
Old Jan 9, 2005 | 04:51 PM
JeffW's Avatar
Engine: 305 tpi LB9
here is the fronts
Old Jan 9, 2005 | 11:48 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Wilwoods front and rear.
Fronts: 12.9"x1.25, 6pot, 2pc rotors (4 lbs lighter each side than the factory 10.5"x1.0, single piston iron caliper setup)
Rears: 12.2"x.81, 4pot, 2pc rotors, internal drum parking brake.
(Not weighed)
Old Jan 10, 2005 | 01:07 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
SSBC's
Old Jan 10, 2005 | 04:17 PM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
Porsche 993TT front and Corvette "front's" on rear.
Fronts:13"x1.25", 4pot, 2pc rotors
Rears: 13"x1.1", 2pot, 1pc rotors, external mechanical parking brake
Old Jan 10, 2005 | 05:33 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
z06 fronts , 13x1.25.
Old Jan 10, 2005 | 07:39 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
My front 1LEs.
<img src=http://memimage.cardomain.net/member_images/6/web/342000-342999/342885_5_full.jpg>
Old Jan 11, 2005 | 08:17 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
C4 up front. 1LE out back.
Old Jan 11, 2005 | 05:48 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Nothin special here, just Powerstop crossdrilled with Powerstop pads
Old Jan 12, 2005 | 05:18 PM
luke j's Avatar
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
i have ls1s on the front, stock 10.5 rear disc for now, getting ls1 rears soon.
Old Jan 12, 2005 | 05:24 PM
luke j's Avatar
could not get the pic in the last post.
Old Jan 15, 2005 | 09:30 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Fronts: 12.1" x 1.375" Coleman rotors with WilWood SuperliteII 4 piston calipers. ( 1.75" Pistons )
Old Jan 15, 2005 | 09:42 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Rears: 1LE rotor with 4 Piston SuperliteII calipers ( 1.375" pistons ).
Old Jan 16, 2005 | 12:22 PM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
Not finished yet, but here is an inprogress shot of LS1's on the rear:
Old Jan 17, 2005 | 06:38 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
CHickenman, can you give me a little info on that front setup? I'm trying to put together a setup for a '69 Chevy truck and Camaro and was curious as to which part number you used for the hub section. I need to check dimentions.
Thanks!
Ed
Old Jan 17, 2005 | 11:55 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
C5 fronts. LS1 rears. I love em. Some guys squack about caliper spread and other issues for all out racing but these things are literally LIGHT YEARS above the factory offerings. Especially noticable at speed! Whoot :lala:
Old Jan 17, 2005 | 12:25 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Thanks!
Ed
Isn't the bolt circle diameter on the truck 5x5"? Is Camaro a '69 as well? 5x4.75" for Camaro I believe.
Complete info available here:
https://www.thirdgen.org/techbb2/sho...ghlight=Nascar
Edit: BTW, I would not recommend the "WilWood Cold Stopper" pads ( Tan in color). They are not acceptable for track use. Not enough retardation. OK for street pads though.
Old Jan 17, 2005 | 01:36 PM
ebmiller88's Avatar
Yes, a '69 Camaro (not mine)and yes the pattern on the truck is 5 on 5". That's why I need a whole custom setup. Can't use C5 parts like I had hoped since the truck hub is too big to fit behind it. I can use a C5 caliper since I can get a rotor 1.25" thick. I know the inner hub hole is larger as is the outer bearing..it's a bonzer! I don't know what I will end up doing yet but I was curious as to the specs of your hub. What's your inner hub diameter? The truck hub will have to be about 7" inside diameter.
Ed
Old Jan 17, 2005 | 01:56 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Hey ed how about a heavy Chevy rotor? Mid seventies full size Impalas and wagons used the 5 on 5 and the bearings were large. Might be the same as truck. Worth a look into if you haven't already.
Chickenman nice set up man! That car must be a hoot to run. Don't sell it
Old Jan 17, 2005 | 08:20 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Ed
Inner hub diameter 6.51". Wilwood has all the specs at their site:
http://www.wilwood.com/Products/003-...order_info.pdf
Why such a large ( 7" ) inside diameter? That's huge and may be a problem.
Old Jan 18, 2005 | 09:57 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
13 inch baers
Old Feb 25, 2005 | 07:52 AM
PiotrGliwice's Avatar
Car: Camaro RS '91
Transmission: TH700
Hi
are the C5 calipers bigger than C4 ?
will they fitt to 16" rims?
Piotr
Old Feb 25, 2005 | 08:01 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Yes they are bigger than the C4 stuff but its not the size of the caliper thats so much the issue with fitting the C5's on the 16" wheels as it is the large diameter of the rotor so no they wont clear 16" wheels. At least none that I know of.
Old Feb 25, 2005 | 08:10 AM
Car: Camaro RS '91
Transmission: TH700
are the C5 calipers bigger than C4 (HD 13") ?
Inside diameter rims is 14.95"
Piotr
Old Feb 25, 2005 | 09:42 AM
ebmiller88's Avatar
Yes, C5 calipers are larger, and no the C5s won't fit 16" wheels..The C4 HDs DO fit 16" wheels tho.
Ed
Old Mar 1, 2005 | 08:16 PM
semiller26's Avatar
Car: 1986 Trans Am
here's another snyper with candy underneath.
<img src="http://memimage.cardomain.net/member_images/5/web/473000-473999/473585_59_full.jpg">
Old Mar 1, 2005 | 08:29 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Ed's 13" C4HD's
Old Mar 2, 2005 | 09:47 AM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Will a C5 caliper on an LS1 rotor fit a 16 x 8 N96 IROC wheel?
Old Mar 2, 2005 | 08:15 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
GM C5 rotor with Wilwood Superlite II 4 piston caliper:
Attached Thumbnails post your brake pics (not stock)-c-documents-settings-matt
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Linson
Aug 21, 2015 02:12 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
