going from drum to disc
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
oaky guys i need to know everything needed for this swap.i have an 89 camaro maro with drums in the rear ,i found an 87 iroc at the junk yard with rear disc.now i already tokk of the big plte in the back that the dust sheild/mounting bracket correct?then alot of bolt and nuts.ebrake brackets and mounting stuff.all the lines bended already from the car.wat else do i need besides rotors and calipers?also wat do i have to do to complete this swap?like wat do i remove from the drums step by step instruction will be nice
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
get the chapest rotrs you can an evry1 nos you need a bunch of holes an slots u can do youself mark out a pattern with a sharpy markr an dril them and make shure dey r even to keep the ballances correct then take a dreml toll and put a sferical grinder in it you make th slots in it this way afta you dun take them to the locole chrom shop to get them chromed this will keep them lookin new for a LOOOOOOOONG time but to make this work you have to use the cheapest pads 2 sinc they will have to take the chome off where the pad goes then replace with the pads u want trust me this the best way to you stop you're maro camaro
Car: '88 Formula
pattern shmattern just make shure it balanced you can bring it to your local machine shoop fo them to wiegth it rite they add or remov materal so it spin right
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
should be fairly simple every thing should swap right over, now that u have the knowledge about ho to remove the disk set up ull understand how it all comes together once you get the drums assemblies off... the bolt pattern on the hubs is the same.....correct me if im wrong...
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Owww my eyes....funny one, Slow.
HA! That was a good one, on the sly. I had my own response but I held off...there's only 3 threads going right now on the same topic.
Ed
Ed
Car: 89 Camaro RS
Engine: 5.0 tbi
also one more quick ? do i need to get a diffrent master cylinder?i know i need a diffrent prop vavle and i alreay have one.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Why bother wasting your time with the '87 rear brakes anyways...aren't those the ones that had issues? Sorry if I'm putting out bad information, I didn't think the rear brakes were actually decent until the 1LE brakes came out. Your stock drums are better than the original disc brakes on these cars.
Car: '88 Formula
Incredible.... absolutely incredible.
Why don’t you go ask your friend and apparent teammate over at ‘Team Undercontrol.’ Just to jog your memory he did the same thing and thought his combo valve caused 2 brake lines to burst. We don't want that to happen to you now do we? I think you should use the new combo valve AND get an adjustable proportioning valve. Just to make sure you don’t leak brake fluid all over the place.
https://www.thirdgen.org/techbb2/sho...hreadid=257277
But then again… aren’t you supposed to be the guy with all the answers Mr. Master Mechanic? I wish I could find that thread where you advertised your services and everyone ripped you a new one based on all the basic questions you ask like… tell me how to do my brakes step by step!!
Car: 89 Camaro RS
Engine: 5.0 tbi
the other guy wasnt leaking by the lines it was by the seal of the ebrake bracket.so he replace both calipers and problem slove.so should i change the master or not?the master for drums and disc is the same part# at autozone im confused
That's because the same master was used from '90-92 on both drum and disc cars so they probably only gave you one number. Use it, you'll be fine.
Ed
Ed
Car: '88 Formula
Ed, it looks like you're getting sucked into the darkside.
If you're swapping parts you want to get the stuff from the 'DONOR' car. So if you get brake parts off an '87... then you tell the guy at the parts counter you have an '87.... yada yada yada
Just a few quick clicks got me this. Ed was right, 90-92 got the same master cylinder no matter what brakes came on the car. '87's got 2 different masters, 1 for disk/drum and 1 for disk/disk. This should answer all your questions now... and all that are about to hit you eventually.
Car: '88 Formula
Car: '88 Formula
I'm getting ready to throw out a set of them myself... maybe I should tell this guy that I've fixed them and they work perfectly just like the stuff he tries to sell everyone else.
Now I'm feeling dumber for giving him that link since he likes to screw people over and doesn't care at all.
Car: 89 Camaro RS
Engine: 5.0 tbi
well i found that advance auto parts has the right master .so im getting it from them along with some pads.and then the calipers from autozone so im set thanks alot guys.
Car: 1997 Corvette
Have you not been listening to me? Your drum brakes better be shot or something. Why the hell you would replace them with '87 rear discs is beyond me. If you're going to go through the work to put discs on the rear, at least go with 1LE/LT1 brakes.
Car: 89 Camaro RS
Engine: 5.0 tbi
hey guys doing the swap in 2 weeks but need some quick help, all 89 master cylinders for both drums and disc have the same part #?didnt they use the same master 90 up?because if in 89 they were the same to i could use the one already and the car.now for the 87 they show 2 diffrent part # for the master but will 87 master and 87 prop vavle bolt on to my lines perfect?because i have an 89 prop vavle that i know will match up with all the lines.but then 87 master and 89 prop vavle will that work as in all the lines bolt on?
Car: 89 Camaro RS
Engine: 5.0 tbi
yeah i figure that out at the junk yard,when i took apart the 2 differnt years and they bolted on fine.thanks alot guys
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
DuronClocker, im guessing that you know more about brakes then i do because i always thought discs were better than drums. this is incorrect?
Car: 1997 Corvette
Not when the drum brakes are actually decent and the 82-88 rear disc brakes sucked.. Very little line pressure gets to the back brakes. This makes drums more effective in the back than discs because calipers require a much higher line pressure to be effective than a wheel cylinder (drum brakes) does.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The early disc brakes take a regular beating on TGO (they certainly could have been better and the PBR's are a definate improvement), but with the repair kit, they worked fine for all practical driving situations. I used the parking brake regularly and never experienced any problems.
JamesC
JamesC
Car: 89 Camaro RS
Engine: 5.0 tbi
well my buddy has the 87 rear disc and he attends scca solo 2 races and his brakes work great and all he has is hawks pads all around and an 89 prop vavle for awd
Car: 1995 K1500 Yukon 2-Dr and 1982 Z-28
Engine: truck: 350hp 454 car: 485hp 355
Transmission: truck:5spd car: Doug Nash 5spd
Axle/Gears: truck: stock car: Dana44 w 3:23
Re: going from drum to disc
i made this change on my 82 camaro in 1987 and have had no problems- (not sure what year the donor car was) at the time i found the "4 wheel disk" master cylinder had a larger bore the rear drum model. a rear drum master will have no "pedal" and will work like you have out-of-adjustment rear brakes.
https://www.thirdgen.org/forums/susp...fferences.html
JamesC
is the j50 the regular drum/disk master, or a different disk/disk master?
KO1
16
Oct 15, 2015 05:00 PM
